이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Press the valve all the way down with a screwdriver to release the air pressure.
Use a 5/32 inch hex key to unscrew the 5/32 hex-head bolts that hold the rim halves together.
Flip the tire so that the bottom side is on the top now.
Pull out the bottom rim half that contains the nuts for the bolts.
Don't forget to visually inspect outside of tire for foreign objects that may have punctured your original tube. Also feel around inside of tire carefully for such objects (nails, screws, wire, thorns, etc).
Use two fingers to uniformly push the replacement inner tube into the inside of the tire.
Spread the replacement inner tube evenly against the walls of the tire.
Gently pull out the valve stem so that it faces you. You may have to flip the tire to make it face you.
Take the bottom rim half and partially push it into the bottom of the tire. The bottom rim half contains the nuts for the bolts.
Align the valve stem cutout in the bottom rim half with the valve stem.
Push the bottom rim half into the tire until the valve stem and rim touch.
Locate the valve stem cutout on the top rim half.
Align the valve stem cutout on the top rim half with the valve stem.
Push the top rim half into the tire until the two rim halves touch.
Insert all the bolts into the top rim half.
Use a 5/32 inch hex key to screw the bolts in.
Use an air compressor with a tire inflator attachment (or any car tire inflator) to inflate the tire.
다른 한 분이 해당 안내서를 완성하였습니다.
