주요 콘텐츠로 건너뛰기
WRS315SDHW Auger Motor Replacement
필요한 것
  1. WRS315SDHW Auger Motor Replacement, Safety precautions: 1 단계, 이미지 1개 중 1개
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. WRS315SDHW Auger Motor Replacement, Open the doors: 2 단계, 이미지 3개 중 1개 WRS315SDHW Auger Motor Replacement, Open the doors: 2 단계, 이미지 3개 중 2개 WRS315SDHW Auger Motor Replacement, Open the doors: 2 단계, 이미지 3개 중 3개
    • Depending on your repair, open one or both doors.
  3. WRS315SDHW Auger Motor Replacement, Remove the icemaker tray: 3 단계, 이미지 2개 중 1개 WRS315SDHW Auger Motor Replacement, Remove the icemaker tray: 3 단계, 이미지 2개 중 2개
    • Pull the icemaker tray completely out of its slot in the chassis.
  4. WRS315SDHW Auger Motor Replacement, Unfasten the icemaker assembly: 4 단계, 이미지 2개 중 1개 WRS315SDHW Auger Motor Replacement, Unfasten the icemaker assembly: 4 단계, 이미지 2개 중 2개
    • Use a 1/4 inch socket wrench to remove the three screws securing the icemaker assembly (shown with the assembly removed):
    • Two 23.9 mm-long screws
    • One 16.7 mm-long screw
  5. WRS315SDHW Auger Motor Replacement, Reposition the icemaker assembly: 5 단계, 이미지 3개 중 1개 WRS315SDHW Auger Motor Replacement, Reposition the icemaker assembly: 5 단계, 이미지 3개 중 2개 WRS315SDHW Auger Motor Replacement, Reposition the icemaker assembly: 5 단계, 이미지 3개 중 3개
    • Pull the icemaker assembly toward the right edge of the refrigerator to release it from its slot in the chassis.
    • Let the icemaker assembly hang to access its connector.
  6. WRS315SDHW Auger Motor Replacement, Disconnect the icemaker assembly: 6 단계, 이미지 3개 중 1개 WRS315SDHW Auger Motor Replacement, Disconnect the icemaker assembly: 6 단계, 이미지 3개 중 2개 WRS315SDHW Auger Motor Replacement, Disconnect the icemaker assembly: 6 단계, 이미지 3개 중 3개
    • Disconnect the spade connector attached to the icemaker assembly.
  7. WRS315SDHW Auger Motor Replacement, Remove the icemaker assembly: 7 단계, 이미지 1개 중 1개
    • Remove the icemaker assembly.
  8. WRS315SDHW Auger Motor Replacement, Unfasten the icemaker auger assembly: 8 단계, 이미지 1개 중 1개
    • Use a 1/4 inch socket wrench to remove the four screws securing the icemaker auger assembly:
    • Two 24.1 mm-long screws
    • Two 16.5 mm-long screws
  9. WRS315SDHW Auger Motor Replacement, Reposition the icemaker auger assembly: 9 단계, 이미지 3개 중 1개 WRS315SDHW Auger Motor Replacement, Reposition the icemaker auger assembly: 9 단계, 이미지 3개 중 2개 WRS315SDHW Auger Motor Replacement, Reposition the icemaker auger assembly: 9 단계, 이미지 3개 중 3개
    • Pull the icemaker auger assembly off of its slot in the chassis.
    • Let the assembly hang to access its connector.
  10. WRS315SDHW Auger Motor Replacement, Disconnect the icemaker auger assembly: 10 단계, 이미지 3개 중 1개 WRS315SDHW Auger Motor Replacement, Disconnect the icemaker auger assembly: 10 단계, 이미지 3개 중 2개 WRS315SDHW Auger Motor Replacement, Disconnect the icemaker auger assembly: 10 단계, 이미지 3개 중 3개
    • Use a flathead screwdriver, or a similar tool, to compress the connector attached to the icemaker auger assembly.
    • Use your hands to disconnect the assembly connector.
  11. WRS315SDHW Auger Motor Replacement, Remove the icemaker auger assembly: 11 단계, 이미지 1개 중 1개
    • Remove the icemaker auger assembly.
  12. WRS315SDHW Auger Motor Replacement, Remove the auger fin: 12 단계, 이미지 3개 중 1개 WRS315SDHW Auger Motor Replacement, Remove the auger fin: 12 단계, 이미지 3개 중 2개 WRS315SDHW Auger Motor Replacement, Remove the auger fin: 12 단계, 이미지 3개 중 3개
    • Twist the auger fin clockwise until it separates from the assembly.
    • Remove the auger fin.
  13. WRS315SDHW Auger Motor Replacement, Unfasten the grounding wire: 13 단계, 이미지 1개 중 1개
    • Use a 1/4 inch socket wrench, or a flathead screwdriver, to remove the 11.6 mm-long screw securing the grounding wire.
  14. WRS315SDHW Auger Motor Replacement, Unfasten the auger motor: 14 단계, 이미지 1개 중 1개
    • Use a 1/4 inch socket wrench to remove the three 16.7 mm-long screws securing the auger motor.
  15. WRS315SDHW Auger Motor Replacement, Disconnect the auger motor: 15 단계, 이미지 2개 중 1개 WRS315SDHW Auger Motor Replacement, Disconnect the auger motor: 15 단계, 이미지 2개 중 2개
    • Use needle nose pliers, or your hands, to disconnect the grounding wire from the auger motor.
  16. WRS315SDHW Auger Motor Replacement: 16 단계, 이미지 3개 중 1개 WRS315SDHW Auger Motor Replacement: 16 단계, 이미지 3개 중 2개 WRS315SDHW Auger Motor Replacement: 16 단계, 이미지 3개 중 3개
    • Disconnect the two spade connectors attached to the auger motor.
  17. WRS315SDHW Auger Motor Replacement, Only the auger motor remains: 17 단계, 이미지 1개 중 1개
    • You're now left with the auger motor.
결론
Repair didn’t go as planned? Ask our Answers community for help.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
nicO
회원 가입일: 04/14/15
15,927 평판
안내서 89개를 작성함
Global Fixers Global Fixers 회원
Community
45 회원들
안내서 702개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 7
전체 시간: 159
