주요 콘텐츠로 건너뛰기
WRS315SDHW Condenser Fan Replacement
필요한 것
  1. WRS315SDHW Condenser Fan Replacement, Safety precautions: 1 단계, 이미지 1개 중 1개
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. WRS315SDHW Condenser Fan Replacement, Unfasten the rear panel: 2 단계, 이미지 3개 중 1개 WRS315SDHW Condenser Fan Replacement, Unfasten the rear panel: 2 단계, 이미지 3개 중 2개 WRS315SDHW Condenser Fan Replacement, Unfasten the rear panel: 2 단계, 이미지 3개 중 3개
    • Use a 1/4 inch socket wrench, or a flathead screwdriver, to remove the seven 16.2 mm-long screws securing the rear panel.
    • Use a 1/4 inch socket wrench to loosen the screw securing the water hose enough for the rear panel to freely move.
  3. WRS315SDHW Condenser Fan Replacement, Remove the rear panel: 3 단계, 이미지 3개 중 1개 WRS315SDHW Condenser Fan Replacement, Remove the rear panel: 3 단계, 이미지 3개 중 2개 WRS315SDHW Condenser Fan Replacement, Remove the rear panel: 3 단계, 이미지 3개 중 3개
    • Pull the rear panel off the chassis to remove it.
  4. WRS315SDHW Condenser Fan Replacement, Disconnect the condenser fan: 4 단계, 이미지 2개 중 1개 WRS315SDHW Condenser Fan Replacement, Disconnect the condenser fan: 4 단계, 이미지 2개 중 2개
    • Press the tab on the condenser fan cable connector to unclip it.
    • Pull the connector straight out of its slot to remove it.
  5. WRS315SDHW Condenser Fan Replacement, Remove the condenser fan: 5 단계, 이미지 3개 중 1개 WRS315SDHW Condenser Fan Replacement, Remove the condenser fan: 5 단계, 이미지 3개 중 2개 WRS315SDHW Condenser Fan Replacement, Remove the condenser fan: 5 단계, 이미지 3개 중 3개
    • Put on gloves before continuing, as the sheet metal and the fan itself are sharp.
    • Pull the condenser fan straight off its peg to remove it.
  6. WRS315SDHW Condenser Fan Replacement, Unfasten the condenser fan motor: 6 단계, 이미지 1개 중 1개
    • Use a 1/4 inch socket wrench to remove the four 16.5 mm-long screws securing the condenser fan motor to the chassis.
  7. WRS315SDHW Condenser Fan Replacement, Remove the motor: 7 단계, 이미지 3개 중 1개 WRS315SDHW Condenser Fan Replacement, Remove the motor: 7 단계, 이미지 3개 중 2개 WRS315SDHW Condenser Fan Replacement, Remove the motor: 7 단계, 이미지 3개 중 3개
    • Rotate the motor housing through its slot in the chassis.
    • Remove the motor.
결론
Repair didn’t go as planned? Ask our Answers community for help.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
nicO
회원 가입일: 04/14/15
15,927 평판
안내서 89개를 작성함
Global Fixers Global Fixers 회원
Community
45 회원들
안내서 702개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 3
전체 시간: 133
