주요 콘텐츠로 건너뛰기
WRS315SDHW Defrost Heater Replacement
필요한 것
  1. WRS315SDHW Defrost Heater Replacement, Safety precautions: 1 단계, 이미지 1개 중 1개
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. WRS315SDHW Defrost Heater Replacement, Open the doors: 2 단계, 이미지 3개 중 1개 WRS315SDHW Defrost Heater Replacement, Open the doors: 2 단계, 이미지 3개 중 2개 WRS315SDHW Defrost Heater Replacement, Open the doors: 2 단계, 이미지 3개 중 3개
    • Depending on your repair, open one or both doors.
  3. WRS315SDHW Defrost Heater Replacement, Remove the drawers: 3 단계, 이미지 2개 중 1개 WRS315SDHW Defrost Heater Replacement, Remove the drawers: 3 단계, 이미지 2개 중 2개
    • Remove the drawers and shelves from the freezer section.
  4. WRS315SDHW Defrost Heater Replacement: 4 단계, 이미지 2개 중 1개 WRS315SDHW Defrost Heater Replacement: 4 단계, 이미지 2개 중 2개
    • Remove the screw(s) securing the evaporator cover.
  5. WRS315SDHW Defrost Heater Replacement, Unclip the evaporator cover: 5 단계, 이미지 3개 중 1개 WRS315SDHW Defrost Heater Replacement, Unclip the evaporator cover: 5 단계, 이미지 3개 중 2개 WRS315SDHW Defrost Heater Replacement, Unclip the evaporator cover: 5 단계, 이미지 3개 중 3개
    • Lift the bottom of the evaporator cover up and over its lip in the chassis.
    • Pull the cover toward yourself to release its top clips.
  6. WRS315SDHW Defrost Heater Replacement, Remove the evaporator cover: 6 단계, 이미지 3개 중 1개 WRS315SDHW Defrost Heater Replacement, Remove the evaporator cover: 6 단계, 이미지 3개 중 2개 WRS315SDHW Defrost Heater Replacement, Remove the evaporator cover: 6 단계, 이미지 3개 중 3개
    • Continue pulling the evaporator cover towards yourself to unclip its metal prongs from the chassis.
    • Remove the evaporator cover.
  7. WRS315SDHW Defrost Heater Replacement, Disconnect the defrost heater: 7 단계, 이미지 3개 중 1개 WRS315SDHW Defrost Heater Replacement, Disconnect the defrost heater: 7 단계, 이미지 3개 중 2개 WRS315SDHW Defrost Heater Replacement, Disconnect the defrost heater: 7 단계, 이미지 3개 중 3개
    • Disconnect the two spade connectors attached to the defrost heater.
  8. WRS315SDHW Defrost Heater Replacement, Reposition the cable: 8 단계, 이미지 3개 중 1개 WRS315SDHW Defrost Heater Replacement, Reposition the cable: 8 단계, 이미지 3개 중 2개 WRS315SDHW Defrost Heater Replacement, Reposition the cable: 8 단계, 이미지 3개 중 3개
    • Pull the defrost heater cable out from behind the evaporator.
  9. WRS315SDHW Defrost Heater Replacement, Unfasten the defrost heater bracket: 9 단계, 이미지 1개 중 1개
    • Use a 1/4 inch socket wrench to remove the 16.5 mm-long screw securing the defrost heater bracket.
  10. WRS315SDHW Defrost Heater Replacement, Release the defrost heater bracket: 10 단계, 이미지 2개 중 1개 WRS315SDHW Defrost Heater Replacement, Release the defrost heater bracket: 10 단계, 이미지 2개 중 2개
    • Pull the defrost heater bracket up to release it from its slot in the chassis.
  11. WRS315SDHW Defrost Heater Replacement, Remove the defrost heater: 11 단계, 이미지 3개 중 1개 WRS315SDHW Defrost Heater Replacement, Remove the defrost heater: 11 단계, 이미지 3개 중 2개 WRS315SDHW Defrost Heater Replacement, Remove the defrost heater: 11 단계, 이미지 3개 중 3개
    • Slide the defrost heater from under the evaporator.
    • You may need to pull one end at a time until it's completely removed.
  12. WRS315SDHW Defrost Heater Replacement, Only the defrost heater remains: 12 단계, 이미지 1개 중 1개
    • You're now left with the defrost heater.
결론
Repair didn’t go as planned? Ask our Answers community for help.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
nicO
회원 가입일: 04/14/15
15,927 평판
안내서 89개를 작성함
Global Fixers Global Fixers 회원
Community
45 회원들
안내서 702개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 15
전체 시간: 249
