주요 콘텐츠로 건너뛰기
WRS315SDHW Dispenser Solenoid Replacement
필요한 것
  1. WRS315SDHW Dispenser Solenoid Replacement, Safety precautions: 1 단계, 이미지 1개 중 1개
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. WRS315SDHW Dispenser Solenoid Replacement, Open the doors: 2 단계, 이미지 3개 중 1개 WRS315SDHW Dispenser Solenoid Replacement, Open the doors: 2 단계, 이미지 3개 중 2개 WRS315SDHW Dispenser Solenoid Replacement, Open the doors: 2 단계, 이미지 3개 중 3개
    • Depending on your repair, open one or both doors.
  3. WRS315SDHW Dispenser Solenoid Replacement, Remove the icemaker tray: 3 단계, 이미지 2개 중 1개 WRS315SDHW Dispenser Solenoid Replacement, Remove the icemaker tray: 3 단계, 이미지 2개 중 2개
    • Pull the icemaker tray completely out of its slot in the chassis.
  4. WRS315SDHW Dispenser Solenoid Replacement, Unfasten the icemaker assembly: 4 단계, 이미지 2개 중 1개 WRS315SDHW Dispenser Solenoid Replacement, Unfasten the icemaker assembly: 4 단계, 이미지 2개 중 2개
    • Use a 1/4 inch socket wrench to remove the three screws securing the icemaker assembly (shown with the assembly removed):
    • Two 23.9 mm-long screws
    • One 16.7 mm-long screw
  5. WRS315SDHW Dispenser Solenoid Replacement, Reposition the icemaker assembly: 5 단계, 이미지 3개 중 1개 WRS315SDHW Dispenser Solenoid Replacement, Reposition the icemaker assembly: 5 단계, 이미지 3개 중 2개 WRS315SDHW Dispenser Solenoid Replacement, Reposition the icemaker assembly: 5 단계, 이미지 3개 중 3개
    • Pull the icemaker assembly toward the right edge of the refrigerator to release it from its slot in the chassis.
    • Let the icemaker assembly hang to access its connector.
  6. WRS315SDHW Dispenser Solenoid Replacement, Disconnect the icemaker assembly: 6 단계, 이미지 3개 중 1개 WRS315SDHW Dispenser Solenoid Replacement, Disconnect the icemaker assembly: 6 단계, 이미지 3개 중 2개 WRS315SDHW Dispenser Solenoid Replacement, Disconnect the icemaker assembly: 6 단계, 이미지 3개 중 3개
    • Disconnect the spade connector attached to the icemaker assembly.
  7. WRS315SDHW Dispenser Solenoid Replacement, Remove the icemaker assembly: 7 단계, 이미지 1개 중 1개
    • Remove the icemaker assembly.
  8. WRS315SDHW Dispenser Solenoid Replacement, Unfasten the icemaker auger assembly: 8 단계, 이미지 1개 중 1개
    • Use a 1/4 inch socket wrench to remove the four screws securing the icemaker auger assembly:
    • Two 24.1 mm-long screws
    • Two 16.5 mm-long screws
  9. WRS315SDHW Dispenser Solenoid Replacement, Reposition the icemaker auger assembly: 9 단계, 이미지 3개 중 1개 WRS315SDHW Dispenser Solenoid Replacement, Reposition the icemaker auger assembly: 9 단계, 이미지 3개 중 2개 WRS315SDHW Dispenser Solenoid Replacement, Reposition the icemaker auger assembly: 9 단계, 이미지 3개 중 3개
    • Pull the icemaker auger assembly off of its slot in the chassis.
    • Let the assembly hang to access its connector.
  10. WRS315SDHW Dispenser Solenoid Replacement, Disconnect the icemaker auger assembly: 10 단계, 이미지 3개 중 1개 WRS315SDHW Dispenser Solenoid Replacement, Disconnect the icemaker auger assembly: 10 단계, 이미지 3개 중 2개 WRS315SDHW Dispenser Solenoid Replacement, Disconnect the icemaker auger assembly: 10 단계, 이미지 3개 중 3개
    • Use a flathead screwdriver, or a similar tool, to compress the connector attached to the icemaker auger assembly.
    • Use your hands to disconnect the assembly connector.
  11. WRS315SDHW Dispenser Solenoid Replacement, Remove the icemaker auger assembly: 11 단계, 이미지 1개 중 1개
    • Remove the icemaker auger assembly.
  12. WRS315SDHW Dispenser Solenoid Replacement, Remove the dispenser: 12 단계, 이미지 3개 중 1개 WRS315SDHW Dispenser Solenoid Replacement, Remove the dispenser: 12 단계, 이미지 3개 중 2개 WRS315SDHW Dispenser Solenoid Replacement, Remove the dispenser: 12 단계, 이미지 3개 중 3개
    • Slide the dispenser head out of its slot in the icemaker auger assembly.
  13. WRS315SDHW Dispenser Solenoid Replacement: 13 단계, 이미지 2개 중 1개 WRS315SDHW Dispenser Solenoid Replacement: 13 단계, 이미지 2개 중 2개
    • Remove the dispenser head out of its metal solenoid cube.
  14. WRS315SDHW Dispenser Solenoid Replacement, Remove the tape: 14 단계, 이미지 3개 중 1개 WRS315SDHW Dispenser Solenoid Replacement, Remove the tape: 14 단계, 이미지 3개 중 2개 WRS315SDHW Dispenser Solenoid Replacement, Remove the tape: 14 단계, 이미지 3개 중 3개
    • Peel the tape off the solenoid connector.
    • Set the tape aside. You'll reuse it during reassembly.
  15. WRS315SDHW Dispenser Solenoid Replacement, Disconnect the solenoid: 15 단계, 이미지 3개 중 1개 WRS315SDHW Dispenser Solenoid Replacement, Disconnect the solenoid: 15 단계, 이미지 3개 중 2개 WRS315SDHW Dispenser Solenoid Replacement, Disconnect the solenoid: 15 단계, 이미지 3개 중 3개
    • Pull the solenoid spade connector straight out of the solenoid to disconnect it.
결론
Repair didn’t go as planned? Ask our Answers community for help.
작성자
2다른 기여자 명과 함께
nicO
회원 가입일: 04/14/15
15,927 평판
안내서 89개를 작성함
Global Fixers Global Fixers 회원
Community
45 회원들
안내서 702개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 3
전체 시간: 98
