주요 콘텐츠로 건너뛰기
WRS315SDHW Drain Pan Replacement
필요한 것
  1. WRS315SDHW Drain Pan Replacement, Safety precautions: 1 단계, 이미지 1개 중 1개
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. WRS315SDHW Drain Pan Replacement, Open the doors: 2 단계, 이미지 3개 중 1개 WRS315SDHW Drain Pan Replacement, Open the doors: 2 단계, 이미지 3개 중 2개 WRS315SDHW Drain Pan Replacement, Open the doors: 2 단계, 이미지 3개 중 3개
    • Depending on your repair, open one or both doors.
  3. WRS315SDHW Drain Pan Replacement, Unfasten the front panel: 3 단계, 이미지 3개 중 1개 WRS315SDHW Drain Pan Replacement, Unfasten the front panel: 3 단계, 이미지 3개 중 2개 WRS315SDHW Drain Pan Replacement, Unfasten the front panel: 3 단계, 이미지 3개 중 3개
    • Use a Phillips driver to remove the two 15.2 mm-long screws securing the front panel.
  4. WRS315SDHW Drain Pan Replacement, Remove the front panel: 4 단계, 이미지 3개 중 1개 WRS315SDHW Drain Pan Replacement, Remove the front panel: 4 단계, 이미지 3개 중 2개 WRS315SDHW Drain Pan Replacement, Remove the front panel: 4 단계, 이미지 3개 중 3개
    • Pull the front panel straight off the chassis and remove it.
    • You may have to slightly open the water filter door to remove the front panel completely.
  5. WRS315SDHW Drain Pan Replacement, Unfasten the wiring harness: 5 단계, 이미지 1개 중 1개
    • Use a 1/4 inch socket wrench to remove the 16.7 mm-long screw securing the wiring harness.
  6. WRS315SDHW Drain Pan Replacement, Reposition the wiring harness: 6 단계, 이미지 2개 중 1개 WRS315SDHW Drain Pan Replacement, Reposition the wiring harness: 6 단계, 이미지 2개 중 2개
    • Pull the wiring harness out of its slot in the chassis to access its connectors.
  7. WRS315SDHW Drain Pan Replacement, Disconnect the wiring harness: 7 단계, 이미지 3개 중 1개 WRS315SDHW Drain Pan Replacement, Disconnect the wiring harness: 7 단계, 이미지 3개 중 2개 WRS315SDHW Drain Pan Replacement, Disconnect the wiring harness: 7 단계, 이미지 3개 중 3개
    • Disconnect the two connectors attached to the door wiring harness.
  8. WRS315SDHW Drain Pan Replacement, Unfasten the rear panel: 8 단계, 이미지 3개 중 1개 WRS315SDHW Drain Pan Replacement, Unfasten the rear panel: 8 단계, 이미지 3개 중 2개 WRS315SDHW Drain Pan Replacement, Unfasten the rear panel: 8 단계, 이미지 3개 중 3개
    • Use a 1/4 inch socket wrench, or a flathead screwdriver, to remove the seven 16.2 mm-long screws securing the rear panel.
    • Use a 1/4 inch socket wrench to loosen the screw securing the water hose enough for the rear panel to freely move.
  9. WRS315SDHW Drain Pan Replacement, Remove the rear panel: 9 단계, 이미지 3개 중 1개 WRS315SDHW Drain Pan Replacement, Remove the rear panel: 9 단계, 이미지 3개 중 2개 WRS315SDHW Drain Pan Replacement, Remove the rear panel: 9 단계, 이미지 3개 중 3개
    • Pull the rear panel off the chassis to remove it.
  10. WRS315SDHW Drain Pan Replacement, Remove the condenser fan: 10 단계, 이미지 3개 중 1개 WRS315SDHW Drain Pan Replacement, Remove the condenser fan: 10 단계, 이미지 3개 중 2개 WRS315SDHW Drain Pan Replacement, Remove the condenser fan: 10 단계, 이미지 3개 중 3개
    • Put on gloves before continuing, as the sheet metal and the condenser fan itself are sharp.
    • Pull the condenser fan straight off its peg to remove it.
  11. WRS315SDHW Drain Pan Replacement, Unclip the drain pan: 11 단계, 이미지 2개 중 1개 WRS315SDHW Drain Pan Replacement, Unclip the drain pan: 11 단계, 이미지 2개 중 2개
    • Use a flathead screwdriver, or a similar tool, to pry up the metal clip from the back of the drain pan.
  12. WRS315SDHW Drain Pan Replacement, Reposition the wiring harness: 12 단계, 이미지 3개 중 1개 WRS315SDHW Drain Pan Replacement, Reposition the wiring harness: 12 단계, 이미지 3개 중 2개 WRS315SDHW Drain Pan Replacement, Reposition the wiring harness: 12 단계, 이미지 3개 중 3개
    • Pull the wiring harness straight out of the chassis until you can access the drain pan.
  13. WRS315SDHW Drain Pan Replacement, Peel the tape: 13 단계, 이미지 3개 중 1개 WRS315SDHW Drain Pan Replacement, Peel the tape: 13 단계, 이미지 3개 중 2개 WRS315SDHW Drain Pan Replacement, Peel the tape: 13 단계, 이미지 3개 중 3개
    • Peel the tape off the front metal clip attached to the drain pan.
  14. WRS315SDHW Drain Pan Replacement, Unclip the drain pan: 14 단계, 이미지 3개 중 1개 WRS315SDHW Drain Pan Replacement, Unclip the drain pan: 14 단계, 이미지 3개 중 2개 WRS315SDHW Drain Pan Replacement, Unclip the drain pan: 14 단계, 이미지 3개 중 3개
    • Use your fingers to release the metal clip on the front of the drain pan.
    • Fold the metal clip so that it lays flat on the floor of the chassis.
  15. WRS315SDHW Drain Pan Replacement, Remove the drain pan: 15 단계, 이미지 3개 중 1개 WRS315SDHW Drain Pan Replacement, Remove the drain pan: 15 단계, 이미지 3개 중 2개 WRS315SDHW Drain Pan Replacement, Remove the drain pan: 15 단계, 이미지 3개 중 3개
    • Pull the drain pan toward the front of the chassis to release any remaining clips.
    • Remove the drain pan.
결론
Repair didn’t go as planned? Ask our Answers community for help.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
nicO
회원 가입일: 04/14/15
15,927 평판
안내서 89개를 작성함
Global Fixers Global Fixers 회원
Community
45 회원들
안내서 702개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 3
전체 시간: 95
