주요 콘텐츠로 건너뛰기
WRS315SDHW Evaporator Fan Replacement
필요한 것
  1. WRS315SDHW Evaporator Fan Replacement, Safety precautions: 1 단계, 이미지 1개 중 1개
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. WRS315SDHW Evaporator Fan Replacement, Open the doors: 2 단계, 이미지 3개 중 1개 WRS315SDHW Evaporator Fan Replacement, Open the doors: 2 단계, 이미지 3개 중 2개 WRS315SDHW Evaporator Fan Replacement, Open the doors: 2 단계, 이미지 3개 중 3개
    • Depending on your repair, open one or both doors.
  3. WRS315SDHW Evaporator Fan Replacement, Remove the drawers: 3 단계, 이미지 2개 중 1개 WRS315SDHW Evaporator Fan Replacement, Remove the drawers: 3 단계, 이미지 2개 중 2개
    • Remove the drawers and shelves from the freezer section.
  4. WRS315SDHW Evaporator Fan Replacement: 4 단계, 이미지 2개 중 1개 WRS315SDHW Evaporator Fan Replacement: 4 단계, 이미지 2개 중 2개
    • Remove the screw(s) securing the evaporator cover.
  5. WRS315SDHW Evaporator Fan Replacement, Unclip the evaporator cover: 5 단계, 이미지 3개 중 1개 WRS315SDHW Evaporator Fan Replacement, Unclip the evaporator cover: 5 단계, 이미지 3개 중 2개 WRS315SDHW Evaporator Fan Replacement, Unclip the evaporator cover: 5 단계, 이미지 3개 중 3개
    • Lift the bottom of the evaporator cover up and over its lip in the chassis.
    • Pull the cover toward yourself to release its top clips.
  6. WRS315SDHW Evaporator Fan Replacement, Remove the evaporator cover: 6 단계, 이미지 3개 중 1개 WRS315SDHW Evaporator Fan Replacement, Remove the evaporator cover: 6 단계, 이미지 3개 중 2개 WRS315SDHW Evaporator Fan Replacement, Remove the evaporator cover: 6 단계, 이미지 3개 중 3개
    • Continue pulling the evaporator cover towards yourself to unclip its metal prongs from the chassis.
    • Remove the evaporator cover.
  7. WRS315SDHW Evaporator Fan Replacement, Disconnect the evaporator fan: 7 단계, 이미지 2개 중 1개 WRS315SDHW Evaporator Fan Replacement, Disconnect the evaporator fan: 7 단계, 이미지 2개 중 2개
    • Use needle nose pliers, or your fingers, to disconnect the grounding wire attached to the evaporator fan.
  8. WRS315SDHW Evaporator Fan Replacement: 8 단계, 이미지 3개 중 1개 WRS315SDHW Evaporator Fan Replacement: 8 단계, 이미지 3개 중 2개 WRS315SDHW Evaporator Fan Replacement: 8 단계, 이미지 3개 중 3개
    • Disconnect the connector attached to the evaporator fan.
  9. WRS315SDHW Evaporator Fan Replacement, Unfasten the evaporator fan: 9 단계, 이미지 1개 중 1개
    • Use a 1/4 inch socket wrench to remove the two 13 mm-long screws securing the evaporator fan.
  10. WRS315SDHW Evaporator Fan Replacement, Remove the foam buffers: 10 단계, 이미지 3개 중 1개 WRS315SDHW Evaporator Fan Replacement, Remove the foam buffers: 10 단계, 이미지 3개 중 2개 WRS315SDHW Evaporator Fan Replacement, Remove the foam buffers: 10 단계, 이미지 3개 중 3개
    • Slide the foam buffer downward to release it from its lip in the chassis.
    • Remove the foam buffer.
    • Repeat this procedure for the second foam buffer.
  11. WRS315SDHW Evaporator Fan Replacement, Remove the evaporator fan housing: 11 단계, 이미지 3개 중 1개 WRS315SDHW Evaporator Fan Replacement, Remove the evaporator fan housing: 11 단계, 이미지 3개 중 2개 WRS315SDHW Evaporator Fan Replacement, Remove the evaporator fan housing: 11 단계, 이미지 3개 중 3개
    • Pull the evaporator fan housing up and outward from the chassis to remove it.
  12. WRS315SDHW Evaporator Fan Replacement, Remove the fan: 12 단계, 이미지 2개 중 1개 WRS315SDHW Evaporator Fan Replacement, Remove the fan: 12 단계, 이미지 2개 중 2개
    • Pull the evaporator fan straight off its motor to remove it.
    • This may require some significant force.
  13. WRS315SDHW Evaporator Fan Replacement, Remove the motor bracket: 13 단계, 이미지 3개 중 1개 WRS315SDHW Evaporator Fan Replacement, Remove the motor bracket: 13 단계, 이미지 3개 중 2개 WRS315SDHW Evaporator Fan Replacement, Remove the motor bracket: 13 단계, 이미지 3개 중 3개
    • Use your fingers to pry up and release the motor bracket clips from the housing.
  14. WRS315SDHW Evaporator Fan Replacement, Remove the motor bracket: 14 단계, 이미지 2개 중 1개 WRS315SDHW Evaporator Fan Replacement, Remove the motor bracket: 14 단계, 이미지 2개 중 2개
    • Remove the motor bracket.
  15. WRS315SDHW Evaporator Fan Replacement, Remove the motor: 15 단계, 이미지 3개 중 1개 WRS315SDHW Evaporator Fan Replacement, Remove the motor: 15 단계, 이미지 3개 중 2개 WRS315SDHW Evaporator Fan Replacement, Remove the motor: 15 단계, 이미지 3개 중 3개
    • Pull the motor straight out of its housing to remove it.
결론
Repair didn’t go as planned? Ask our Answers community for help.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
nicO
회원 가입일: 04/14/15
15,927 평판
안내서 89개를 작성함
Global Fixers Global Fixers 회원
Community
45 회원들
안내서 702개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 10
전체 시간: 164
