주요 콘텐츠로 건너뛰기
WRS315SDHW Start Relay Assembly Replacement
필요한 것
  1. WRS315SDHW Start Relay Assembly Replacement, Safety precautions: 1 단계, 이미지 1개 중 1개
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. WRS315SDHW Start Relay Assembly Replacement, Unfasten the rear panel: 2 단계, 이미지 3개 중 1개 WRS315SDHW Start Relay Assembly Replacement, Unfasten the rear panel: 2 단계, 이미지 3개 중 2개 WRS315SDHW Start Relay Assembly Replacement, Unfasten the rear panel: 2 단계, 이미지 3개 중 3개
    • Use a 1/4 inch socket wrench, or a flathead screwdriver, to remove the seven 16.2 mm-long screws securing the rear panel.
    • Use a 1/4 inch socket wrench to loosen the screw securing the water hose enough for the rear panel to freely move.
  3. WRS315SDHW Start Relay Assembly Replacement, Remove the rear panel: 3 단계, 이미지 3개 중 1개 WRS315SDHW Start Relay Assembly Replacement, Remove the rear panel: 3 단계, 이미지 3개 중 2개 WRS315SDHW Start Relay Assembly Replacement, Remove the rear panel: 3 단계, 이미지 3개 중 3개
    • Pull the rear panel off the chassis to remove it.
  4. WRS315SDHW Start Relay Assembly Replacement, Disconnect the start relay assembly: 4 단계, 이미지 3개 중 1개 WRS315SDHW Start Relay Assembly Replacement, Disconnect the start relay assembly: 4 단계, 이미지 3개 중 2개 WRS315SDHW Start Relay Assembly Replacement, Disconnect the start relay assembly: 4 단계, 이미지 3개 중 3개
    • Use a flathead screwdriver, or a similar tool, to disconnect the connector attached to the start relay assembly.
  5. WRS315SDHW Start Relay Assembly Replacement, Unclip the start relay assembly: 5 단계, 이미지 3개 중 1개 WRS315SDHW Start Relay Assembly Replacement, Unclip the start relay assembly: 5 단계, 이미지 3개 중 2개 WRS315SDHW Start Relay Assembly Replacement, Unclip the start relay assembly: 5 단계, 이미지 3개 중 3개
    • Pull the metal clip out its hole in the top of the start relay assembly.
    • Rest the clip next to the assembly.
  6. WRS315SDHW Start Relay Assembly Replacement, Remove the start relay assembly: 6 단계, 이미지 3개 중 1개 WRS315SDHW Start Relay Assembly Replacement, Remove the start relay assembly: 6 단계, 이미지 3개 중 2개 WRS315SDHW Start Relay Assembly Replacement, Remove the start relay assembly: 6 단계, 이미지 3개 중 3개
    • Pull the start relay assembly straight off its prongs in the chassis.
    • Remove the start relay assembly.
    • The assembly consists of the start capacitor, start relay, and overload relay.
결론
Repair didn’t go as planned? Ask our Answers community for help.
작성자
3다른 기여자 명과 함께
nicO
회원 가입일: 04/14/15
15,927 평판
안내서 89개를 작성함
Global Fixers Global Fixers 회원
Community
45 회원들
안내서 702개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 1
전체 시간: 113
