주요 콘텐츠로 건너뛰기
WRS315SDHW Temperature Control Board Replacement
필요한 것
  1. WRS315SDHW Temperature Control Board Replacement, Safety precautions: 1 단계, 이미지 1개 중 1개
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. WRS315SDHW Temperature Control Board Replacement, Open the doors: 2 단계, 이미지 3개 중 1개 WRS315SDHW Temperature Control Board Replacement, Open the doors: 2 단계, 이미지 3개 중 2개 WRS315SDHW Temperature Control Board Replacement, Open the doors: 2 단계, 이미지 3개 중 3개
    • Depending on your repair, open one or both doors.
  3. WRS315SDHW Temperature Control Board Replacement, Unfasten the temperature control board assembly: 3 단계, 이미지 2개 중 1개 WRS315SDHW Temperature Control Board Replacement, Unfasten the temperature control board assembly: 3 단계, 이미지 2개 중 2개
    • Use a 1/4 inch socket wrench, or a flathead screwdriver, to remove the 22.3 mm-long screw securing the temperature control board assembly.
  4. WRS315SDHW Temperature Control Board Replacement, Reposition the assembly: 4 단계, 이미지 3개 중 1개 WRS315SDHW Temperature Control Board Replacement, Reposition the assembly: 4 단계, 이미지 3개 중 2개 WRS315SDHW Temperature Control Board Replacement, Reposition the assembly: 4 단계, 이미지 3개 중 3개
    • Pull the temperature control board assembly off its slot in the chassis.
    • Let the assembly hang to access its connectors.
  5. WRS315SDHW Temperature Control Board Replacement, Disconnect the temperature control board: 5 단계, 이미지 3개 중 1개 WRS315SDHW Temperature Control Board Replacement, Disconnect the temperature control board: 5 단계, 이미지 3개 중 2개 WRS315SDHW Temperature Control Board Replacement, Disconnect the temperature control board: 5 단계, 이미지 3개 중 3개
    • Disconnect the two spade connectors attached to the temperature control board assembly.
  6. WRS315SDHW Temperature Control Board Replacement, Remove the assembly: 6 단계, 이미지 1개 중 1개
    • Remove the temperature control board assembly.
  7. WRS315SDHW Temperature Control Board Replacement, Separate the temperature control board: 7 단계, 이미지 3개 중 1개 WRS315SDHW Temperature Control Board Replacement, Separate the temperature control board: 7 단계, 이미지 3개 중 2개 WRS315SDHW Temperature Control Board Replacement, Separate the temperature control board: 7 단계, 이미지 3개 중 3개
    • Use a flathead screwdriver, or a similar tool, to compress the plastic clip securing the temperature control board.
    • Use another flathead screwdriver to pry up the board from its housing.
  8. WRS315SDHW Temperature Control Board Replacement, Remove the temperature control board: 8 단계, 이미지 1개 중 1개
    • Pull the temperature control board straight out of its housing to remove it.
결론
Repair didn’t go as planned? Ask our Answers community for help.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
nicO
회원 가입일: 04/14/15
15,927 평판
안내서 89개를 작성함
Global Fixers Global Fixers 회원
Community
45 회원들
안내서 702개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 109
