소개
Use this guide to replace the carburetor on a Wacker PG1 (2014) Pump.
필요한 것
Before beginning repairs, disconnect and remove all hoses.
Flip the motor ignition switch into the OFF position.
Use your fingers to pinch the locking tab on the top of the air box cover.
While pulling down on the throttle pulley, use your finger to lift the throttle linkage out of its slot on the pulley.
Use a pair of needle nose pliers to compress the two hose clamp tabs on the black hose.
While compressing the tabs, slide the hose clamp up and off of the carburetor nipple.
다른 한 분이 해당 안내서를 완성하였습니다.
