주요 콘텐츠로 건너뛰기
Wacker Pump PG1 2014 Impeller Replacement
필요한 것
  1. Wacker Pump PG1 2014 Impeller Replacement, Safety precautions: 1 단계, 이미지 1/2 Wacker Pump PG1 2014 Impeller Replacement, Safety precautions: 1 단계, 이미지 2/2
    • Before beginning repairs, disconnect and remove all hoses.
    • Flip the motor ignition switch into the OFF position.
  2. Wacker Pump PG1 2014 Impeller Replacement, Float Chamber Housing: 2 단계, 이미지 1/1
    • Use a 13 mm socket to remove the two bolts securing the handle.
  3. Wacker Pump PG1 2014 Impeller Replacement: 3 단계, 이미지 1/2 Wacker Pump PG1 2014 Impeller Replacement: 3 단계, 이미지 2/2
    • Remove the handle.
  4. Wacker Pump PG1 2014 Impeller Replacement: 4 단계, 이미지 1/1
    • Use a 13 mm socket to remove the two bolts securing the float chamber housing.
  5. Wacker Pump PG1 2014 Impeller Replacement: 5 단계, 이미지 1/3 Wacker Pump PG1 2014 Impeller Replacement: 5 단계, 이미지 2/3 Wacker Pump PG1 2014 Impeller Replacement: 5 단계, 이미지 3/3
    • Remove the float chamber housing.
  6. Wacker Pump PG1 2014 Impeller Replacement, Remove the engine cover: 6 단계, 이미지 1/1
    • Use a 4 mm hex key to remove the bolt securing the engine cover.
  7. Wacker Pump PG1 2014 Impeller Replacement: 7 단계, 이미지 1/2 Wacker Pump PG1 2014 Impeller Replacement: 7 단계, 이미지 2/2
    • Lift up to remove the engine cover.
  8. Wacker Pump PG1 2014 Impeller Replacement, Block the fan blades: 8 단계, 이미지 1/2 Wacker Pump PG1 2014 Impeller Replacement, Block the fan blades: 8 단계, 이미지 2/2
    • The impeller is threaded onto the motor's output shaft and will need to be loosened. In order to stop the shaft from rotating, the motor fan assembly will need to be blocked.
    • Insert a flathead screwdriver between two fan blades on the motor fan assembly.
  9. Wacker Pump PG1 2014 Impeller Replacement, Loosen the impeller: 9 단계, 이미지 1/1
    • Tap the impeller on one of its blades with a rubber mallet and a punch to break it loose from the threads on the output shaft.
  10. Wacker Pump PG1 2014 Impeller Replacement, Remove the impeller: 10 단계, 이미지 1/3 Wacker Pump PG1 2014 Impeller Replacement, Remove the impeller: 10 단계, 이미지 2/3 Wacker Pump PG1 2014 Impeller Replacement, Remove the impeller: 10 단계, 이미지 3/3
    • Use your fingers to unthread and remove the impeller.
    • With the impeller removed, the seal kit spring will become loose and may fall out.
결론
Carsten Frauenheim
회원 가입일: 03/10/20
86,081 평판
안내서 332개 작성하였습니다
iFixit iFixit 회원
Community
140 회원들
안내서 16,860개 작성하였습니다
0 Comments
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 7
전체 시간: 95
