주요 콘텐츠로 건너뛰기
Wacom Cintiq 24HD Power Button Replacement
필요한 것
  1. Wacom Cintiq 24HD Power Button Replacement, Stand: 1 단계, 이미지 1/1
    • Unplug any cables from the USB, power, display or DVI-D ports by gripping the cord by the connector and pulling straight out of the port.
    • Unplugging the cables by pulling on the cord or pulling at an angle can damage the cable or connector.
  2. Wacom Cintiq 24HD Power Button Replacement: 2 단계, 이미지 1/3 Wacom Cintiq 24HD Power Button Replacement: 2 단계, 이미지 2/3 Wacom Cintiq 24HD Power Button Replacement: 2 단계, 이미지 3/3
    • Place the device screen down on a flat surface.
    • Remove eight 10mm Phillips #2 screws (four on each leg of the stand) by turning the screwdriver counterclockwise.
  3. Wacom Cintiq 24HD Power Button Replacement: 3 단계, 이미지 1/1
    • Lift the stand up and away from the rest of the device so the legs separate from the mounting plate.
  4. Wacom Cintiq 24HD Power Button Replacement, Back Panel: 4 단계, 이미지 1/3 Wacom Cintiq 24HD Power Button Replacement, Back Panel: 4 단계, 이미지 2/3 Wacom Cintiq 24HD Power Button Replacement, Back Panel: 4 단계, 이미지 3/3
    • Remove eighteen 10.2mm Phillips #1 screws from the perimeter of the back panel by turning the screwdriver counterclockwise.
    • Remove one 11.9mm Phillips #1 screw from the center of the back panel.
    • Remove two 10.2mm Phillips #1 screws from underneath hinged panels in the bottom right and left corners.
    • Our device does not include the cover panels for the USB, DVI-D, and power ports. You must first remove these cover panels shown in green in order to remove the back panel.
  5. Wacom Cintiq 24HD Power Button Replacement: 5 단계, 이미지 1/2 Wacom Cintiq 24HD Power Button Replacement: 5 단계, 이미지 2/2
    • Lift the back panel up by a corner and insert a plastic opening tool in the gap.
    • Slide the tool along the gap around the perimeter of the device while lifting to unlatch the back panel.
    • The latches on the back panel will make loud clicking noises when opening.
    • Remove the panel by lifting it up and off of the device.
  6. Wacom Cintiq 24HD Power Button Replacement, Power Button: 6 단계, 이미지 1/2 Wacom Cintiq 24HD Power Button Replacement, Power Button: 6 단계, 이미지 2/2
    • Remove the rubber cover on the power button by lifting up and off.
  7. Wacom Cintiq 24HD Power Button Replacement: 7 단계, 이미지 1/1
    • Remove the two 9.5mm Phillips #2 screws by turning the screwdriver counterclockwise.
  8. Wacom Cintiq 24HD Power Button Replacement: 8 단계, 이미지 1/2 Wacom Cintiq 24HD Power Button Replacement: 8 단계, 이미지 2/2
    • Remove the cable connected to the button board by pinching close to the connector and pulling the wiring straight out from the port.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Jay Sung
회원 가입일: 10/08/18
481 평판
안내서 4개 작성하였습니다
Cal Poly, Team S15-G3, White Fall 2018 Cal Poly, Team S15-G3, White Fall 2018 회원
CPSU-WHITE-F18S15G3
4 회원들
안내서 18개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 24
전체 시간: 1,711
