주요 콘텐츠로 건너뛰기
기기를 고치세요
수리할 권리
부품 & 도구
소개
The power port in the Wacom Cintiq 24HD can fail over time due to overuse. The power port must function in order for the Cintiq to work. This guide will show you how to replace the power port. Soldering skills and tools will be needed for this replacement. iFixit has a guide to soldering which you can find here.
  1. Unplug any cables from the USB, power, display or DVI-D ports  by  gripping the  cord by the connector and pulling straight out of the port.
    • Unplug any cables from the USB, power, display or DVI-D ports by gripping the cord by the connector and pulling straight out of the port.
    • Unplugging the cables by pulling on the cord or pulling at an angle can damage the cable or connector.
  2. Place the device screen down on a flat surface. Remove eight 10mm Phillips #2 screws (four on each leg of the stand) by turning the screwdriver counterclockwise. Remove eight 10mm Phillips #2 screws (four on each leg of the stand) by turning the screwdriver counterclockwise.
    • Place the device screen down on a flat surface.
    • Remove eight 10mm Phillips #2 screws (four on each leg of the stand) by turning the screwdriver counterclockwise.
  3. Lift the stand up and away from the rest of the device so the legs separate from the mounting plate.
    • Lift the stand up and away from the rest of the device so the legs separate from the mounting plate.
  4. Remove eighteen 10.2mm Phillips #1 screws from the perimeter of the back panel by turning the screwdriver counterclockwise. Remove one 11.9mm Phillips #1 screw from the center of the back panel. Remove two 10.2mm Phillips #1 screws from underneath hinged panels in the bottom right and left corners.
    • Remove eighteen 10.2mm Phillips #1 screws from the perimeter of the back panel by turning the screwdriver counterclockwise.
    • Remove one 11.9mm Phillips #1 screw from the center of the back panel.
    • Remove two 10.2mm Phillips #1 screws from underneath hinged panels in the bottom right and left corners.
    • Our device does not include the cover panels for the USB, DVI-D, and power ports. You must first remove these cover panels shown in green in order to remove the back panel.
  5. Lift the back panel up by a corner and  insert a plastic opening tool in the gap. Slide the tool along the gap around the perimeter of the  device while lifting to  unlatch the back panel.
    • Lift the back panel up by a corner and insert a plastic opening tool in the gap.
    • Slide the tool along the gap around the perimeter of the device while lifting to unlatch the back panel.
    • The latches on the back panel will make loud clicking noises when opening.
    • Remove the panel by lifting it up and off of the device.
  6. Nintendo Switch 키트
    게임으로 돌아가기 위한 빠른 해결책
    Nintendo Switch 키트 쇼핑하기
    Nintendo Switch 키트
    게임으로 돌아가기 위한 빠른 해결책
  7. Detach the small black wire connecting the back metal plate to the USB video port by removing the one 8 mm Phillips #2 screw from the back metal plate and turning the screwdriver counterclockwise. Detach the small black wire connecting the back metal plate to the USB video port by removing the one 8 mm Phillips #2 screw from the back metal plate and turning the screwdriver counterclockwise. Detach the small black wire connecting the back metal plate to the USB video port by removing the one 8 mm Phillips #2 screw from the back metal plate and turning the screwdriver counterclockwise.
    • Detach the small black wire connecting the back metal plate to the USB video port by removing the one 8 mm Phillips #2 screw from the back metal plate and turning the screwdriver counterclockwise.
  8. Remove the two 8 mm Phillips #2 screws from the metal button plate by rotating the screwdriver counterclockwise. Remove the metal button plate from the back metal plate. Remove the metal button plate from the back metal plate.
    • Remove the two 8 mm Phillips #2 screws from the metal button plate by rotating the screwdriver counterclockwise.
    • Remove the metal button plate from the back metal plate.
  9. Remove the button wires from the support clip by pushing down on the clip. Detach the button wires from the button board by pulling the button wires away from the board. Place the button board back in to the device.
    • Remove the button wires from the support clip by pushing down on the clip.
    • Detach the button wires from the button board by pulling the button wires away from the board.
    • Place the button board back in to the device.
  10. Remove the eight (four on each plate) 10.2mm Phillips #2 screws with locking washers from the metal mounting plates by rotating the screwdriver counterclockwise. Remove the two metal mounting plates. Remove the two metal mounting plates.
    • Remove the eight (four on each plate) 10.2mm Phillips #2 screws with locking washers from the metal mounting plates by rotating the screwdriver counterclockwise.
    • Remove the two metal mounting plates.
  11. Remove the sixteen 8 mm Phillips #2 screws with flanges from the horizontal side of the plate by turning the screwdriver counterclockwise. Remove the ten 8 mm Phillips #2 screws with flanges from  the vertical sides of the plate by turning the screwdriver counterclockwise. Remove the ten 8 mm Phillips #2 screws with flanges from  the vertical sides of the plate by turning the screwdriver counterclockwise.
    • Remove the sixteen 8 mm Phillips #2 screws with flanges from the horizontal side of the plate by turning the screwdriver counterclockwise.
    • Remove the ten 8 mm Phillips #2 screws with flanges from the vertical sides of the plate by turning the screwdriver counterclockwise.
  12. Remove the back metal plate by lifting up along one edge , then lifting the plate off and away from the device.
    • Remove the back metal plate by lifting up along one edge , then lifting the plate off and away from the device.
  13. Remove the two 7.8mm Phillips #2 screws from the right back panel connected to the power port by turning the screwdriver counterclockwise.
    • Remove the two 7.8mm Phillips #2 screws from the right back panel connected to the power port by turning the screwdriver counterclockwise.
  14. Lift the power port and attached daughterboard out of the device. Remove the wires from the daughterboard.
    • Lift the power port and attached daughterboard out of the device.
    • Remove the wires from the daughterboard.
    • Pull gently on the wires when removing from the daughterboard to prevent any tearing.
  15. Remove the two 8 mm Phillips #2 screws from the daughterboard by turning the screwdriver counterclockwise. Detach the metal cover from the power port.
    • Remove the two 8 mm Phillips #2 screws from the daughterboard by turning the screwdriver counterclockwise.
    • Detach the metal cover from the power port.
  16. Desolder the connections the power port connections using a soldering iron. Remove the power port from the daughterboard by lifting it off.
    • Desolder the connections the power port connections using a soldering iron.
    • Remove the power port from the daughterboard by lifting it off.
    • iFixit has a guide to soldering which you can find here.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Sydney Hosokawa
회원 가입일: 2018년 10월 08일
272 평판
안내서 2개 작성하였습니다
Cal Poly, Team S15-G3, White Fall 2018 Cal Poly, Team S15-G3, White Fall 2018 회원
CPSU-WHITE-F18S15G3
4 회원들
안내서 9개 작성하였습니다
could you give the part, so i can buy it please
jmcl21 - 답글
My 24 HD blue power light comes on and off about once a second, you can hear the fan start and stop. Is a faulty power board the reason or is it the ps block ?
Thomas McGarrity - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 7
30일 전: 75
전체 시간: 985
