소개
by the end of the guide you will have replaced your power supply
필요한 것
Procurement of a suitable commercially available power pack.
Type GST120A24R7B
R7B is important as this is the only connector that fits the Wacom tablet. (Connector type KYCON KPPX-4).
Performance data 120W, 24 volts
The power pack opens. To do this, the four rubber plugs are removed and the four screws are removed with a Phillips screwdriver. The housing can then be easily removed.
The 24V side has four wires: black, blue, red and white. These are soldered and can be removed.
The black and blue wire is soldered to the minus output (V-). The red and white wire is soldered to the 24V (V+) output. Note: The black wire is connected to the metal body of the plug.
The power supply will reassemble and can now be connected to the Wacom Tablet.
Work the steps in reverse order to reassemble your device.
다음 번역가들에게 특별히 감사 드립니다:
100%
HelloMacOS님은 저희가 세상을 수리하는데 동참하신 분입니다! 기여하시겠습니까?
번역 시작하기 ›
