주요 콘텐츠로 건너뛰기
Wacom Cintiq 24HD Stand Replacement
필요한 것
  1. Wacom Cintiq 24HD Stand Replacement, Stand: 1 단계, 이미지 1/1
    • Unplug any cables from the USB, power, display or DVI-D ports by gripping the cord by the connector and pulling straight out of the port.
    • Unplugging the cables by pulling on the cord or pulling at an angle can damage the cable or connector.
  2. Wacom Cintiq 24HD Stand Replacement: 2 단계, 이미지 1/3 Wacom Cintiq 24HD Stand Replacement: 2 단계, 이미지 2/3 Wacom Cintiq 24HD Stand Replacement: 2 단계, 이미지 3/3
    • Place the device screen down on a flat surface.
    • Remove eight 10mm Phillips #2 screws (four on each leg of the stand) by turning the screwdriver counterclockwise.
  3. Wacom Cintiq 24HD Stand Replacement: 3 단계, 이미지 1/1
    • Lift the stand up and away from the rest of the device so the legs separate from the mounting plate.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Andrew Fleming
회원 가입일: 10/08/18
408 평판
안내서 3개 작성하였습니다
Cal Poly, Team S15-G3, White Fall 2018 Cal Poly, Team S15-G3, White Fall 2018 회원
CPSU-WHITE-F18S15G3
4 회원들
안내서 18개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 25
전체 시간: 2,085
