이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
The USB accessory port allows users to connect other devices like keyboards, mice, or flash drives to the Cintiq and connected computers. The port can become damaged and stop working with extended use. This guide shows you how to replace the accessory port. You need basic soldering skills and a soldering kit for this replacement guide. iFixit has a guide to soldering which you can find here.
필요한 것
Unplug any cables from the USB, power, display or DVI-D ports by gripping the cord by the connector and pulling straight out of the port.
Remove eighteen 10.2mm Phillips #1 screws from the perimeter of the back panel by turning the screwdriver counterclockwise.
Remove one 11.9mm Phillips #1 screw from the center of the back panel.
Remove two 10.2mm Phillips #1 screws from underneath hinged panels in the bottom right and left corners.
Remove one 8mm Phillips #2 screw by turning the screwdriver counterclockwise
Remove one 9.9mm Phillips #2 screw by turning the screwdriver counterclockwise.
다른 한 분이 해당 안내서를 완성하였습니다.
