주요 콘텐츠로 건너뛰기
Wahl Hair Clippers Model ST115VAC Power Cord Replacement
필요한 것
  1. Wahl Hair Clippers  Model ST115VAC Power Cord  Replacement, Power Cord: 1 단계, 이미지 1/1
    • Unscrew the three 12mm black JIS screw found on the red side of the the device with a JIS #1 driver.
  2. Wahl Hair Clippers  Model ST115VAC Power Cord  Replacement: 2 단계, 이미지 1/1
    • Grab the red cover by the side and lift off the top piece.
  3. Wahl Hair Clippers  Model ST115VAC Power Cord  Replacement: 3 단계, 이미지 1/1
    • Unscrew the 5.556mm screw with a JIS #0 screwdriver. (Black Screw located at power switch)
  4. Wahl Hair Clippers  Model ST115VAC Power Cord  Replacement: 4 단계, 이미지 1/1
    이 단계에 사용된 도구:
    Spudger
    $2.99
    구매
    • Insert the metal spudger between the wire connector and the device connector. The spudger should disengage a tension-like lock between both connectors, and once disengaged gently pry out the cord connection.
    • (Note-dependent on varying user conditions, the connection may be harder to remove and may involve more force or a gentle rocking to separate connection.)
    • When working with electronics, make to use an ESD safe tool, to avoid shock. Try using the black nylon spudger instead.
  5. Wahl Hair Clippers  Model ST115VAC Power Cord  Replacement: 5 단계, 이미지 1/1
    • Remove the cord from the fixed position.
결론
To reassemble your device, follow these instructions in reverse order. When installing new cord, make sure black wire is underneath the white wire.
다른 3명이 해당 안내서를 완성하였습니다.
Julio Alvarado
회원 가입일: 02/15/17
131 평판
안내서 1개 작성함
USF Tampa, Team 10-4, Remmell Spring 2017 USF Tampa, Team 10-4, Remmell Spring 2017 회원
USFT-REMMELL-S17S10G4
4 회원들
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 7
30일 전: 30
전체 시간: 2,945
