주요 콘텐츠로 건너뛰기
Wahl Lithium Ion Trimmer Electric Motor Replacement
필요한 것
  1. Wahl Lithium Ion Trimmer  Electric Motor Replacement, Electric Motor: 1 단계, 이미지 1/1
    • Refer to the 4th step in disassemble process to begin replacement of motor.
  2. Wahl Lithium Ion Trimmer  Electric Motor Replacement: 2 단계, 이미지 1/1
    • Remove the chip set, battery and motor as one piece.
  3. Wahl Lithium Ion Trimmer  Electric Motor Replacement: 3 단계, 이미지 1/1
    • In this step focus on the motor, ignoring the chip set and battery. Here you will be able to remove the motor from the wires.
  4. Wahl Lithium Ion Trimmer  Electric Motor Replacement: 4 단계, 이미지 1/1
    • After the wires are removed and the motor is detached use the replacement motor you purchased and reconnect the wires.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
nathan
회원 가입일: 10/22/13
1,410 평판
안내서 6개 작성하였습니다
University of Maryland, Team 1-3, Shastany Fall 2013 University of Maryland, Team 1-3, Shastany Fall 2013 회원
UMD-SHASTANY-F13S1G3
3 회원들
안내서 6개 작성하였습니다
댓글 한 개
Did you actually find this motor (or an equivalent) for sale? Where?
Marshall Eubanks - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 12
30일 전: 18
전체 시간: 2,755
