주요 콘텐츠로 건너뛰기
Wahl Lithium Ion Trimmer Slide switch Replacement
  1. Wahl Lithium Ion Trimmer  Slide switch Replacement, Slide switch: 1 단계, 이미지 1개 중 1개
    • Start at the last step of the disassembly guide.
  2. Wahl Lithium Ion Trimmer  Slide switch Replacement: 2 단계, 이미지 1개 중 1개
    • remove the inside on the razor which includes the chip set, battery, motor and switch.
  3. Wahl Lithium Ion Trimmer  Slide switch Replacement: 3 단계, 이미지 1개 중 1개
    • focus on the chip set and the white piece on top. The white piece is the switch that turns the razor on and off.
  4. Wahl Lithium Ion Trimmer  Slide switch Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the white piece. Be careful doing so because the chip set is delicate and breaking that would result in replacing that as well.
  5. Wahl Lithium Ion Trimmer  Slide switch Replacement: 5 단계, 이미지 1개 중 1개
    • Upon removing the switch, exchange the broken part with the new one that you bought and replace it. Once installed put the razor back together and now you will be able to turn the razor on and off.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
nathan
회원 가입일: 10/22/13
1,440 평판
안내서 6개를 작성함
1가이드 댓글
Where can you source this part from?
John - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 14
전체 시간: 3,600
