주요 콘텐츠로 건너뛰기
Wahl Lithium Ion Trimmer Lithium Ion Battery Replacement
필요한 것
  1. Wahl Lithium Ion Trimmer Lithium Ion Battery Replacement, Disassembling of Wahl Lithium Ion Trimmer: 1 단계, 이미지 2개 중 1개 Wahl Lithium Ion Trimmer Lithium Ion Battery Replacement, Disassembling of Wahl Lithium Ion Trimmer: 1 단계, 이미지 2개 중 2개
    • Begin by removing the rubber grip along the handle.
  2. Wahl Lithium Ion Trimmer Lithium Ion Battery Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the screws from the top to take the metal piece and plastic part off.
  3. Wahl Lithium Ion Trimmer Lithium Ion Battery Replacement: 3 단계, 이미지 2개 중 1개 Wahl Lithium Ion Trimmer Lithium Ion Battery Replacement: 3 단계, 이미지 2개 중 2개
    • Pry open the plastic cover into two separate pieces. The plastic is very durable so don't worry about breaking it upon prying it open.
  4. Wahl Lithium Ion Trimmer Lithium Ion Battery Replacement, Lithium Ion Battery Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the chip set, motor and battery from the plastic body. This photo shows the motor and wires connecting it to the battery.
  5. Wahl Lithium Ion Trimmer Lithium Ion Battery Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the white plastic cover over the chip set allowing the battery to be taken off.
  6. Wahl Lithium Ion Trimmer Lithium Ion Battery Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the Lithium Ion Battery and replace it with the new one that you purchased.
결론
다른 18명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
nathan
회원 가입일: 10/22/13
1,422 평판
안내서 6개를 작성함
댓글 19개
Great guide but I made the mistake of buying just a standard 3.7v 750mAh battery to try and fit into the trimmer. The battery in the trimmer has metal terminals "stamped" to each end, so the terminals can't be unsoldered from the battery. I was hoping to just unsolder the existing battery and then solder in the new one but no such luck. New trimmer for me now lol
Dean Miller - 답글
DM, I used a dremel tool with a thin grinding wheel to cut off the metal terminals just below the stamp point. After cutting off the metal terminals below the stamp point, approximately 1/4" inch of the terminals still remained which was just enough to connect the new battery to the remaining metal terminals with a small dab of solder. Little bit more work than I was anticipating but the trimmer works like new again. Found the 3.7v 750mAh battery at onlybatteries.com for $5 plus about $5.94 for shipping. Hope this helps for you DIYers!!
Dean Lamborn, 10/25/2015
Dean Lamborn - 답글
Is it an 18650 size?
David Drasser -
Nope, it is a AA size 14500 lithium battery.
Adam Drews -
To Nathan, DM and DL, I was with Nathan until I read about soldering a dremel (which i I own) and cutting off the metal terminals below the stamp point. Can any of you fine 'fixers' show pictures along with the soldering, dremel, cutting, terminals description? I want my Chromado to work like new too! Thanks in advance, Ka
Ka - 답글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 36
지난 30일: 149
전체 시간: 74,939
