주요 콘텐츠로 건너뛰기
Wahl Lithium Ion Trimmer Metal Razor Arms Replacement
필요한 것
  1. Wahl Lithium Ion Trimmer Metal Razor Arms Replacement, Metal Razor Arms: 1 단계, 이미지 1/1
    • Examine the razor to identify any broken or jammed blades that require replacement. If any such blades are identified, the whole set must be changed.
  2. Wahl Lithium Ion Trimmer Metal Razor Arms Replacement: 2 단계, 이미지 1/1
    • Unscrew the two Phillips screws that hold the blades in place with a Phillips #0 screwdriver.
  3. Wahl Lithium Ion Trimmer Metal Razor Arms Replacement: 3 단계, 이미지 1/2 Wahl Lithium Ion Trimmer Metal Razor Arms Replacement: 3 단계, 이미지 2/2
    • Apply pressure to the back side of the blades while pushing outward to remove the blade head completely from the Wahl Lithium Ion Trimmer.
  4. Wahl Lithium Ion Trimmer Metal Razor Arms Replacement: 4 단계, 이미지 1/3 Wahl Lithium Ion Trimmer Metal Razor Arms Replacement: 4 단계, 이미지 2/3 Wahl Lithium Ion Trimmer Metal Razor Arms Replacement: 4 단계, 이미지 3/3
    • Remove the metal clip using a Phillips #0 screwdriver.
  5. Wahl Lithium Ion Trimmer Metal Razor Arms Replacement: 5 단계, 이미지 1/1
    • Separate the Wahl Lithium Ion Trimmer head into its four components. Remove the damaged blade and replace it with a new one.
결론
다른 3명이 해당 안내서를 완성하였습니다.
nathan
회원 가입일: 10/22/13
1,410 평판
안내서 6개 작성하였습니다
University of Maryland, Team 1-3, Shastany Fall 2013 University of Maryland, Team 1-3, Shastany Fall 2013 회원
UMD-SHASTANY-F13S1G3
3 회원들
안내서 6개 작성하였습니다
댓글 3개
Where can I get replacement arms?
Sam - 답글
Where can one obtain a new spring???
tinkrmann - 답글
The spring popped out of the head, but your pictures are too blurry to see how it goes back together.
Mark Wilson - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 15
30일 전: 68
전체 시간: 19,044
