주요 콘텐츠로 건너뛰기
Wahl Lithium Ion Trimmer Motherboard Replacement
필요한 것
  1. Wahl Lithium Ion Trimmer Motherboard Replacement, Disassembling of Wahl Lithium Ion Trimmer: 1 단계, 이미지 2개 중 1개 Wahl Lithium Ion Trimmer Motherboard Replacement, Disassembling of Wahl Lithium Ion Trimmer: 1 단계, 이미지 2개 중 2개
    • Begin by removing the rubber grip along the handle.
  2. Wahl Lithium Ion Trimmer Motherboard Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the screws from the top to take the metal piece and plastic part off.
  3. Wahl Lithium Ion Trimmer Motherboard Replacement: 3 단계, 이미지 2개 중 1개 Wahl Lithium Ion Trimmer Motherboard Replacement: 3 단계, 이미지 2개 중 2개
    • Pry open the plastic cover into two separate pieces. The plastic is very durable so don't worry about breaking it upon prying it open.
  4. Wahl Lithium Ion Trimmer Motherboard Replacement, Motherboard: 4 단계, 이미지 1개 중 1개
    • Remove the motor, battery, and motherboard from the plastic casing.
  5. Wahl Lithium Ion Trimmer Motherboard Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the white plastic piece and the wires from the motherboard.
    • If necessary, cut the wires as close to the motherboard as possible so that you can reconnect them to the new motherboard.
  6. Wahl Lithium Ion Trimmer Motherboard Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the old motherboard and install the new one. Then, connect the wires and white piece to the new motherboard.
결론
작성자
6다른 기여자 명과 함께
nathan
회원 가입일: 10/22/13
1,422 평판
안내서 6개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 8
전체 시간: 3,497
