주요 콘텐츠로 건너뛰기
Wahl Professional Designer Power Switch Replacement
필요한 것
  1. Wahl Professional Designer Power Switch Replacement, Power Switch: 1 단계, 이미지 2개 중 1개 Wahl Professional Designer Power Switch Replacement, Power Switch: 1 단계, 이미지 2개 중 2개
    • Unscrew the 12 mm Phillips head screws located at the top of the cover and at the bottom two corners, using a Phillips #1 Screwdriver.
  2. Wahl Professional Designer Power Switch Replacement: 2 단계, 이미지 2개 중 1개 Wahl Professional Designer Power Switch Replacement: 2 단계, 이미지 2개 중 2개
    • Unscrew the two black 5.556 mm Phillip head screw on the power switch with a Phillips #0 Screwdriver.
  3. Wahl Professional Designer Power Switch Replacement: 3 단계, 이미지 3개 중 1개 Wahl Professional Designer Power Switch Replacement: 3 단계, 이미지 3개 중 2개 Wahl Professional Designer Power Switch Replacement: 3 단계, 이미지 3개 중 3개
    • Shimmy the power switch off the mount until it is completely removed.
결론
작성자
1다른 기여자 명과 함께
Sophia Swearengin
회원 가입일: 09/26/17
790 평판
안내서 5개를 작성함
USF Tampa, Team S14-G5, Boczar Fall 2017 USF Tampa, Team S14-G5, Boczar Fall 2017 회원
USFT-BOCZAR-F17S14G5
2 회원들
안내서 10개를 작성함
1가이드 댓글
Hello Mrs/ms Swearengin, I’m disassembled my Wahl desingner I’m unable to make the power switch stiff . It’s very loose I can’t recall which screw goes in between two black 5.556 mm Phillip head screw or if it needs a screw at all
Carlos Olvera - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 14
전체 시간: 798
