주요 콘텐츠로 건너뛰기
Wand Company Star Trek Communicator Silver Plate Replacement
필요한 것
  1. Wand Company Star Trek Communicator Silver Plate Replacement, Silver Plate: 1 단계, 이미지 1/1
    • Power off the Star trek Bluetooth Communicator before disassembling.
  2. Wand Company Star Trek Communicator Silver Plate Replacement: 2 단계, 이미지 1/2 Wand Company Star Trek Communicator Silver Plate Replacement: 2 단계, 이미지 2/2
    • Remove the four T6 Torx screws (1.70mm) located on the back of the device.
    • Remove the black plastic cover by gently pulling it.
  3. Wand Company Star Trek Communicator Silver Plate Replacement: 3 단계, 이미지 1/2 Wand Company Star Trek Communicator Silver Plate Replacement: 3 단계, 이미지 2/2
    • Remove the protective foam located around the speaker and charging magnets.
    • Be careful not to lose the two magnets located between the microphone and the speaker. The magnets can be easily removed if they come in contact with other magnetic materials.
  4. Wand Company Star Trek Communicator Silver Plate Replacement: 4 단계, 이미지 1/1
    • Remove the two Phillips PH0 (0.9mm) screws located to the side of each magnet.
  5. Wand Company Star Trek Communicator Silver Plate Replacement: 5 단계, 이미지 1/1
    • Remove the black cover.
  6. Wand Company Star Trek Communicator Silver Plate Replacement: 6 단계, 이미지 1/1
    • Remove the protective foam attached to the battery.
  7. Wand Company Star Trek Communicator Silver Plate Replacement: 7 단계, 이미지 1/2 Wand Company Star Trek Communicator Silver Plate Replacement: 7 단계, 이미지 2/2
    • Remove the five Phillips PH0 (0.9mm) screws located at the top and bottom of the silver plate.
  8. Wand Company Star Trek Communicator Silver Plate Replacement: 8 단계, 이미지 1/1
    • Remove the silver plate.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Garret Moses
회원 가입일: 02/15/17
313 평판
안내서 2개 작성하였습니다
USF Tampa, Team 5-6, Passmore Spring 2017 USF Tampa, Team 5-6, Passmore Spring 2017 회원
USFT-PASSMORE-S17S5G6
4 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 7
전체 시간: 572
