주요 콘텐츠로 건너뛰기
Waring 51BL29 Power Cord Replacement
필요한 것
  1. Waring 51BL29 Power Cord Replacement, Bottom Panel: 1 단계, 이미지 1/2 Waring 51BL29 Power Cord Replacement, Bottom Panel: 1 단계, 이미지 2/2
    • Turn the blender on its side so the bottom panel is facing you.
    • Unscrew the 22mm Phillips #1 screw on the indent of the panel.
    • Unscrew the 3 screws in the rubber holes.
  2. Waring 51BL29 Power Cord Replacement: 2 단계, 이미지 1/1
    • Remove the bottom panel.
  3. Waring 51BL29 Power Cord Replacement, Drive Coupling: 3 단계, 이미지 1/1
    • Place the screwdriver in the head of the middle flat-head screw.
  4. Waring 51BL29 Power Cord Replacement: 4 단계, 이미지 1/1
    • Unscrew this screw while holding the coupling with your other hand and not allowing it to rotate.
    • This screw may be reverse-threaded.
  5. Waring 51BL29 Power Cord Replacement: 5 단계, 이미지 1/1
    • Once the coupling mechanism has been loosened all the way, gently pull it off the top of the blender.
  6. Waring 51BL29 Power Cord Replacement, Motor: 6 단계, 이미지 1/2 Waring 51BL29 Power Cord Replacement, Motor: 6 단계, 이미지 2/2
    • Unscrew the four nuts in the bottom of the motor cavity.
    • Wiggle the motor until it is free and you can remove it.
  7. Waring 51BL29 Power Cord Replacement: 7 단계, 이미지 1/1
    • Once motor is pulled out, unscrew the 8 mm screw for the green wire from the base of the blender.
  8. Waring 51BL29 Power Cord Replacement: 8 단계, 이미지 1/3 Waring 51BL29 Power Cord Replacement: 8 단계, 이미지 2/3 Waring 51BL29 Power Cord Replacement: 8 단계, 이미지 3/3
    • Unscrew each white wire cap in order to free the motor from the power cord.
    • Once wire caps are removed, separate wires carefully.
  9. Waring 51BL29 Power Cord Replacement, Power Cord: 9 단계, 이미지 1/1
    • Remove the black power cord.
결론
Quinn Vu
회원 가입일: 04/17/17
113 평판
안내서 1개 작성함
Cal Poly, Team S15-G4, Banghart Spring 2017 Cal Poly, Team S15-G4, Banghart Spring 2017 회원
CPSU-BANGHART-S17S15G4
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 21
전체 시간: 1,776
