주요 콘텐츠로 건너뛰기
Waring Pro SB30 Hot Plate Replacement
필요한 것
  1. Waring Pro SB30 Hot Plate Replacement, Back Panel: 1 단계, 이미지 1/1
    • Remove the screws on the back panel with the #1 Phillips screwdriver bit.
    • The screws in the rubber legs of the burner do not need to be removed.
    • If the back panel has never been opened before, the screws may be more difficult to unscrew.
  2. Waring Pro SB30 Hot Plate Replacement: 2 단계, 이미지 1/2 Waring Pro SB30 Hot Plate Replacement: 2 단계, 이미지 2/2
    • Using a wrench, remove the bolt from the center of the back panel.
  3. Waring Pro SB30 Hot Plate Replacement: 3 단계, 이미지 1/1
    • The back panel can now be easily lifted off.
  4. Waring Pro SB30 Hot Plate Replacement, Hot Plate: 4 단계, 이미지 1/2 Waring Pro SB30 Hot Plate Replacement, Hot Plate: 4 단계, 이미지 2/2
    • Remove screws #1 Phillips screwdriver bit.
    • The interior edges of the metal frame are sharp and can cause minor cuts.
    • 3 screws on the perimeter of the circle
    • 1 screw in the circle
    • 2 screws on the eletrical stands with wires
  5. Waring Pro SB30 Hot Plate Replacement: 5 단계, 이미지 1/2 Waring Pro SB30 Hot Plate Replacement: 5 단계, 이미지 2/2
    • Remove rod from the center of the plate with a wrench.
  6. Waring Pro SB30 Hot Plate Replacement: 6 단계, 이미지 1/2 Waring Pro SB30 Hot Plate Replacement: 6 단계, 이미지 2/2
    • Remove plate carefully as to not damage internal components i.e. insulator, metal frame, wires, etc.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Sun Fai Lau
회원 가입일: 09/22/14
588 평판
안내서 5개 작성하였습니다
USF Tampa, Team 10-7, Brown Fall 2014 USF Tampa, Team 10-7, Brown Fall 2014 회원
USFT-BROWN-F14S10G7
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 7
30일 전: 16
전체 시간: 1,941
