주요 콘텐츠로 건너뛰기
Waring Pro SB30 Indicator Lights Replacement
필요한 것
  1. Waring Pro SB30 Indicator Lights Replacement, Back Panel: 1 단계, 이미지 1/1
    • Remove the screws on the back panel with the #1 Phillips screwdriver bit.
    • The screws in the rubber legs of the burner do not need to be removed.
    • If the back panel has never been opened before, the screws may be more difficult to unscrew.
  2. Waring Pro SB30 Indicator Lights Replacement: 2 단계, 이미지 1/2 Waring Pro SB30 Indicator Lights Replacement: 2 단계, 이미지 2/2
    • Using a wrench, remove the bolt from the center of the back panel.
  3. Waring Pro SB30 Indicator Lights Replacement: 3 단계, 이미지 1/1
    • The back panel can now be easily lifted off.
  4. Waring Pro SB30 Indicator Lights Replacement, Indicator Lights: 4 단계, 이미지 1/1
    • Using two thin screwdrivers (or similar objects) wedge them into the slots of the plastic shell of the desired light.
  5. Waring Pro SB30 Indicator Lights Replacement: 5 단계, 이미지 1/2 Waring Pro SB30 Indicator Lights Replacement: 5 단계, 이미지 2/2
    • Push the screwdrivers inward and guide the bulb outwards.
    • Gently grab by the wires and remove bulb from plastic shell.
결론
Sun Fai Lau
회원 가입일: 09/22/14
588 평판
안내서 5개 작성하였습니다
USF Tampa, Team 10-7, Brown Fall 2014 USF Tampa, Team 10-7, Brown Fall 2014 회원
USFT-BROWN-F14S10G7
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 15
전체 시간: 303
