주요 콘텐츠로 건너뛰기
Warm Audio EQP-WA Tube Replacement
필요한 것
  1. Warm Audio EQP-WA Tube Replacement, Unscrew the cover: 1 단계, 이미지 1/3 Warm Audio EQP-WA Tube Replacement, Unscrew the cover: 1 단계, 이미지 2/3 Warm Audio EQP-WA Tube Replacement, Unscrew the cover: 1 단계, 이미지 3/3
    • Unplug the unit from the mains power before opening it.
    • Remove the screws at the top, sides and back of the unit with a standard phillips screwdriver.
  2. Warm Audio EQP-WA Tube Replacement, Remove the lid: 2 단계, 이미지 1/2 Warm Audio EQP-WA Tube Replacement, Remove the lid: 2 단계, 이미지 2/2
    • Remove the lid and locate the tubes.
  3. Warm Audio EQP-WA Tube Replacement, Remove the shields: 3 단계, 이미지 1/1
    • The tubes are covered by a metal shield. To remove this shield, push down a bit and rotate, then pull up the shield.
  4. Warm Audio EQP-WA Tube Replacement, Replace the tube: 4 단계, 이미지 1/2 Warm Audio EQP-WA Tube Replacement, Replace the tube: 4 단계, 이미지 2/2
    • Pull out the tube that needs changing. Only the glass part comes out.
    • It will probably need some wiggling as you pull.
    • When inserting the new tube, pay attention to how it lines up in the socket, make sure it's completely aligned before pushing, because it will need a good push down and if not aligned correctly, this can bend the tube legs.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
palako
회원 가입일: 02/01/15
962 평판
안내서 7개 작성하였습니다
댓글 3개
¿Y donde encuentras ahora lámparas de esas?
José Ma Palazon - 답글
Thanks for the tutorial !
paul.sasser - 답글
A big mistake here, there is one 12AX7 and one 12AU7, you should specify where goes the AX7 and where the AU7
Chickenwatt - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 32
전체 시간: 2,212
