주요 콘텐츠로 건너뛰기
소개
Hello all, today we will repair a water damaged phone.
it's a simple cell phone and quite easy to repair.
enjoy
부품
지정된 부품이 없습니다.
  1. Water Damage on main board of Nokia 206 RM873, Water Damage on main board of Nokia 206 RM873: 1 단계, 이미지 1/3 Water Damage on main board of Nokia 206 RM873, Water Damage on main board of Nokia 206 RM873: 1 단계, 이미지 2/3 Water Damage on main board of Nokia 206 RM873, Water Damage on main board of Nokia 206 RM873: 1 단계, 이미지 3/3
    • Remove back cover & battery.
  2. Water Damage on main board of Nokia 206 RM873: 2 단계, 이미지 1/2 Water Damage on main board of Nokia 206 RM873: 2 단계, 이미지 2/2
    • Remove the front case by prying it open. You will hear clicks.
    • Be careful with taking off screen if you use a spudger.
  3. Water Damage on main board of Nokia 206 RM873: 3 단계, 이미지 1/2 Water Damage on main board of Nokia 206 RM873: 3 단계, 이미지 2/2
    • Use a Torx screwdriver to remove the screen screws.
    • Use a spudger or tweezers to remove the connector of the LCD screen.
  4. Water Damage on main board of Nokia 206 RM873: 4 단계, 이미지 1/3 Water Damage on main board of Nokia 206 RM873: 4 단계, 이미지 2/3 Water Damage on main board of Nokia 206 RM873: 4 단계, 이미지 3/3
    • Remove keyboard by prying it open with a spudger.
    • The keyboard is secured with adhesive, be careful!
  5. Water Damage on main board of Nokia 206 RM873: 5 단계, 이미지 1/3 Water Damage on main board of Nokia 206 RM873: 5 단계, 이미지 2/3 Water Damage on main board of Nokia 206 RM873: 5 단계, 이미지 3/3
    • The PCB board had water damage, see this in picture 3.
    • To remove the corrosion, dab a cotton swab with a little distilled water on the corroded area, the corrosion will disappear.
  6. Water Damage on main board of Nokia 206 RM873: 6 단계, 이미지 1/2 Water Damage on main board of Nokia 206 RM873: 6 단계, 이미지 2/2
    • How and where to use the cotton swabs.
결론
다른 15명이 해당 안내서를 완성하였습니다.
Kevin D
회원 가입일: 2014년 05월 02일
7,036 평판
안내서 21개 작성하였습니다
4 Comments
no use .it is not switching on . replaced with good batter also. no on
nabhan75 - 답글
try to clean with an ultrasonic bath.
measure out powerrail.
measure out the voltage coming in on board. try to see if you have short.
Kevin D - 답글
Nokia 206 display and charger pin
Mithilesh Yadav - 답글
Not working kiy 1.2.3 and colling ricev kiy not working
K .M Jugesh - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 16
전체 시간: 10,390
