주요 콘텐츠로 건너뛰기
Water Dancing Speakers Refill
필요한 것
  1. Water Dancing Speakers Refill, Water plug & water: 1 단계, 이미지 2개 중 1개 Water Dancing Speakers Refill, Water plug & water: 1 단계, 이미지 2개 중 2개
    • You will need to have a clean work space, water dancing speakers, super glue, mineral water, and Phillips screw driver ready.
    • Unplug the USB cable powering your speakers before you continue.
  2. Water Dancing Speakers Refill: 2 단계, 이미지 1개 중 1개
    • Using the phillips screw driver remove the 4 screws seen on the back of speakers.
  3. Water Dancing Speakers Refill: 3 단계, 이미지 1개 중 1개
    • Once the four screws are taken out you will need to slide the bottom piece from the water canister.
    • When the two are separated set the water canister bottom facing up.
  4. Water Dancing Speakers Refill: 4 단계, 이미지 2개 중 1개 Water Dancing Speakers Refill: 4 단계, 이미지 2개 중 2개
    • On the bottom of the water canister you will see a hole where the water was inserted. There will be a black plug covering the hole.
    • Using your screw driver you can pry the plug out.
    • Once the plug is taken out you can refill the speakers. Only refill the speakers with one inch of water.
  5. Water Dancing Speakers Refill: 5 단계, 이미지 1개 중 1개
    • After the water is filled to approximately one inch. Super glue the hole shut and let dry.
  6. Water Dancing Speakers Refill: 6 단계, 이미지 1개 중 1개
    • When the glue is dry slide speaker back on to water canister.
    • Once they are put together place back panel on and insert the four screws.
    • repeat steps 2 through 6 on second speaker.
결론
Your water dancing speakers are now ready for use. Thank you for using this guide.
다른 48명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Andrew
회원 가입일: 02/17/15
1,387 평판
안내서 2개를 작성함
36가이드 댓글
the pump is defective how to replace
anpicard@videotron.ca
andrepicard2012 - 답글
I couldnt get plug out either so I drilled a hole in back and filled it with mineral water and sealed it with a small strip of scotch tape and duct tape on top of that in case I had to get back in. It works, but now it looks different. Sometimes the water clings to the inside and it looks a little foggy. Is it mineral water, or mineral oil? If it leaks again I'll prob try the oil.
Lacepage - 답글
The original liquid has a lower surface tension than water. I used odorless mineral spirits.
If the pump is noisy, try a drop of oil in the motor.
aeromojito - 답글
My speakers keep spraying even though their is no music playing, is that a good thing?
Andrew - 답글
That means that the speakers are broken. You might need to replace it. If not, then its a probelm with the board, which I have no idea how to fix.
Skittlekingthefirst -
댓글 쓰기
조회 통계:
지난 24시간: 20
지난 7일: 113
지난 30일: 462
전체 시간: 170,963
