주요 콘텐츠로 건너뛰기
Water Tank Sealing Replacement
필요한 것
  1. Water Tank Sealing Replacement, Jura Impressa Type C E F opening procedure: 1 단계, 이미지 1/1
    • The instructions are suitable for nearly every model of Jura and similar ones e.g. AEG and Krups.
    • Unplug!
    • Remove the water reservoir.
  2. Water Tank Sealing Replacement: 2 단계, 이미지 1/3 Water Tank Sealing Replacement: 2 단계, 이미지 2/3 Water Tank Sealing Replacement: 2 단계, 이미지 3/3
    • On the rear side is an obstacle: four "oval head screws" looking like rivets. You can remove them using a special oval drive bit. They are sold at iFixit with the tool kits as well as some Jura suppliers or somewhere in the internet. Jura wants to keep us out of our own machines!
    • Using an oval head bit you can screw them out. If you haven´t got one you can carefully use pliers. It is a good idea to later change the screws for normal ones.
    • You can even create your own specialty tool
    • Beneath both top side covers are two Torx T15 screws. Remove those. Now lift off the whole top cover. Sometimes it jams and you have to use a bit of force.
    • The side covers must be pushed backwards by about 1 cm. Sometimes this is a little bit difficult to move. If necessary, wedge a plastic opening tool into the gap between the side covers and the front panel. The rear cover can be easily removed.
  3. Water Tank Sealing Replacement, Lift support: 3 단계, 이미지 1/2 Water Tank Sealing Replacement, Lift support: 3 단계, 이미지 2/2
    • The support of the sealing is secured by a screw, mostly Tx 15.
    • On the left and right side are notches, open them and raise the support.
    • Turn it upside down.
  4. Water Tank Sealing Replacement, Replace sealing: 4 단계, 이미지 1/3 Water Tank Sealing Replacement, Replace sealing: 4 단계, 이미지 2/3 Water Tank Sealing Replacement, Replace sealing: 4 단계, 이미지 3/3
    • Press both plastic rivets with tiers, then push them out. The cover of the sealing is free.
    • Change sealings. The old one was black, the new one red.
    • Attach cover
결론
Now follow the steps in reverse direction.
다른 4명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
de en
100%
VauWeh님은 저희가 세상을 수리하는데 동참하신 분입니다! 기여하시겠습니까?
번역 시작하기 ›
VauWeh
회원 가입일: 10/19/15
172,542 평판
안내서 219개 작성하였습니다
Repair is War on Entropy Repair is War on Entropy 회원
Community
11 회원들
안내서 772개 작성하였습니다
0 댓글
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 24
30일 전: 103
전체 시간: 10,315
