주요 콘텐츠로 건너뛰기
Weed Whacker Line Replacement
  1. Weed Whacker Line Replacement, Line: 1 단계, 이미지 1/3 Weed Whacker Line Replacement, Line: 1 단계, 이미지 2/3 Weed Whacker Line Replacement, Line: 1 단계, 이미지 3/3
    • Remove cutting line guard from weed whacker. This is usually attached by a wing-nut or a bolt and nut, so it can be removed either by hand or with the correct sized wrench.
  2. Weed Whacker Line Replacement: 2 단계, 이미지 1/1
    • Flip weed whacker upside down so that bottom of cutting piece is facing up.
  3. Weed Whacker Line Replacement: 3 단계, 이미지 1/1
    • There will be a bottom cap of the rotor setup that needs to be removed. In some models this will be held on with a nut and bolt fixture, but in many models there will be a circular cap that can be rotated counter clockwise for removal. Remove this piece in the manner necessary.
  4. Weed Whacker Line Replacement: 4 단계, 이미지 1/2 Weed Whacker Line Replacement: 4 단계, 이미지 2/2
    • Once the bottom piece is removed, there will be another circular piece that may or may not have cutting line coiled around it. Remove this piece from the weed whacker.
  5. Weed Whacker Line Replacement: 5 단계, 이미지 1/2 Weed Whacker Line Replacement: 5 단계, 이미지 2/2
    • There should be slots to coil cutting line around, with a hole in each for line to be anchored. If no line is coiled around the part, insert the end of about three feet of cutting line into each of the holes, and coil the cutting line snugly around the part, making sure that there are no tangles in the line.
  6. Weed Whacker Line Replacement: 6 단계, 이미지 1/1
    • If there are plastic tabs on the plastic part to hold the cutting line, insert each line into one these tabs. Leave approximately a foot of each line hanging out from the coils.
  7. Weed Whacker Line Replacement: 7 단계, 이미지 1/2 Weed Whacker Line Replacement: 7 단계, 이미지 2/2
    • On the weed whacker rotor, there will be eyelets for the cutting line to be fed through. Feed each line through each of these eyelets, being careful not to let the line come uncoiled.
  8. Weed Whacker Line Replacement: 8 단계, 이미지 1/1
    • Replace the plastic piece with the cutting lines back onto the rotor, being sure that the coils remain in place, and the lines remain in place through the eyelets.
  9. Weed Whacker Line Replacement: 9 단계, 이미지 1/1
    • Replace the cap that was removed at the beginning of the assembly.
  10. Weed Whacker Line Replacement: 10 단계, 이미지 1/2 Weed Whacker Line Replacement: 10 단계, 이미지 2/2
    • Replace the cutting line guard.
결승점
다른 2명이 해당 안내서를 완성하였습니다.
Hannah Akey
회원 가입일: 10/02/17
191 평판
안내서 1개 작성함
Michigan Tech, Team S5-G10, Galliah Fall 2017 Michigan Tech, Team S5-G10, Galliah Fall 2017 회원
MTU-GALLIAH-F17S5G10
2 회원들
안내서 1개 작성하였습니다
댓글 한 개
It spins besept not with enough power to cut the grass why is
Mercedes Bush - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 23
전체 시간: 662
