주요 콘텐츠로 건너뛰기
Weinmann VENTImotion and VENTIlogic Display Board Replacement
의료 장비
iFixit과 이 수리 안내서는 의료 기기 제조업체가 보증하지 않으며 제휴 관계가 없습니다.
필요한 것
  1. Weinmann VENTImotion and VENTIlogic Display Board Replacement, Display Board: 1 단계, 이미지 2개 중 1개 Weinmann VENTImotion and VENTIlogic Display Board Replacement, Display Board: 1 단계, 이미지 2개 중 2개
    • Open the device by following these steps:
    • Place the device on a non-slip surface with the top facing downwards
    • Remove the filter cassette from the top part of the housing.
    • Undo and remove the 6 screws (34).
    • Open the bottom of the housing (35) away to the side.
    • Undo the connecting cables for the humidifier (42) and the alarm (43).
    • Make sure the power supply plug is disconnected.
  2. Weinmann VENTImotion and VENTIlogic Display Board Replacement: 3 단계, 이미지 1개 중 1개
    • Disconnect the following:
    • encoder connector (82).
    • connectors of interfaces (84) and (85) off the control board.
  3. Weinmann VENTImotion and VENTIlogic Display Board Replacement: 4 단계, 이미지 1개 중 1개
    • Disconnect the ribbon cable of the display and the fascia film.
    • Pull the latch out until you feel resistance. You can then pull out the ribbon cable.
    • If the latch has not been opened correctly, the ribbon cable may be damaged when it is pulled out.
  4. Weinmann VENTImotion and VENTIlogic Display Board Replacement: 5 단계, 이미지 1개 중 1개
    • Pull flow measurement hoses (56) off the flow sensor.
    • Pull pressure measurement hoses (57) off the pressure sensors.
  5. Weinmann VENTImotion and VENTIlogic Display Board Replacement: 6 단계, 이미지 1개 중 1개
    • Undo the four screws (51) and remove control board (50).
  6. Weinmann VENTImotion and VENTIlogic Display Board Replacement: 7 단계, 이미지 1개 중 1개
    • Remove spring (54) from the control board and remove battery (52) (see "7.9 Replace battery on control board" on page 42).
    • Remove display
  7. Weinmann VENTImotion and VENTIlogic Display Board Replacement: 9 단계, 이미지 1개 중 1개
    • Insert a new display (49).
    • The display may not tilt and must be straight in the guides.
결론
작성자
2다른 기여자 명과 함께
Cameron Young
회원 가입일: 04/22/19
174 평판
안내서 1개를 작성함
Cal Poly, Team S7-G19, Paton Spring 2020 Cal Poly, Team S7-G19, Paton Spring 2020 회원
CPSU-PATON-S20S7G19
3 회원들
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 5
전체 시간: 162
