주요 콘텐츠로 건너뛰기
Weiser Smartcode 10 Touchscreen Electronic Lock Battery Replacement
필요한 것
  1. Weiser Smartcode 10 Touchscreen Electronic Lock Battery Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Unlock your door and open it.
    • Make sure the bolt/latch is fully inside the door before you continue.
  2. Weiser Smartcode 10 Touchscreen Electronic Lock Battery Replacement: 2 단계, 이미지 1개 중 1개
    • Using the Phillips #1 screwdriver, remove the three 8 mm screws on the left, right and bottom side of the cover.
  3. Weiser Smartcode 10 Touchscreen Electronic Lock Battery Replacement: 3 단계, 이미지 1개 중 1개
    • Take the exterior cover off of the door lock.
  4. Weiser Smartcode 10 Touchscreen Electronic Lock Battery Replacement: 4 단계, 이미지 2개 중 1개 Weiser Smartcode 10 Touchscreen Electronic Lock Battery Replacement: 4 단계, 이미지 2개 중 2개
    • Find the battery pack (marked "DOOR" in between two arrows) at the top of the lock.
  5. Weiser Smartcode 10 Touchscreen Electronic Lock Battery Replacement: 5 단계, 이미지 2개 중 1개 Weiser Smartcode 10 Touchscreen Electronic Lock Battery Replacement: 5 단계, 이미지 2개 중 2개
    • Slide the battery pack upwards.
    • Turn the pack over to reveal the batteries.
    • Replace the four AA batteries.
  6. Weiser Smartcode 10 Touchscreen Electronic Lock Battery Replacement: 6 단계, 이미지 1개 중 1개
    • Reinsert the battery pack with the word "DOOR" facing you.
    • Wait until you see a green LED light flashing and/or hear two beeps to indicate working batteries.
    • If there is no green light, repeat steps 5 and 6. Check to see if the batteries are placed correctly or if newer batteries are required.
  7. Weiser Smartcode 10 Touchscreen Electronic Lock Battery Replacement: 7 단계, 이미지 1개 중 1개
    • Check that the bolt/latch is still inside the door.
    • Take the exterior cover and point the narrow end of the knob to the right.
    • Place the cover on the lock and reinsert the screws.
    • Try not to fasten the screws too tightly as they could get damaged in the process.
  8. Weiser Smartcode 10 Touchscreen Electronic Lock Battery Replacement: 8 단계, 이미지 2개 중 1개 Weiser Smartcode 10 Touchscreen Electronic Lock Battery Replacement: 8 단계, 이미지 2개 중 2개
    • To confirm the finished repair, go to the front of the door and place the back of your hand on the touchscreen to activate the keypad.
결론
Congratulations! Make sure to redo this process each year to ensure your device continues to work!
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Brandon Brown
회원 가입일: 05/15/21
214 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 7
지난 7일: 24
지난 30일: 110
전체 시간: 10,306
