이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Place your thumb and forefinger on the blood pressure (NIBP) hose connector. Squeeze the side tabs until the connector releases.
Pull the connector away from the connector port.
Place your thumb and forefinger on the Pulse oximetry (SpO2 or combined SpO2/SpHb) cable connector. Squeeze the side tabs until the connector releases.
Grasp the temperature probe and pull it up to remove it from the monitor.
Remove the cover of the temperature module by pressing the tab and sliding the cover to the right.
Depress the spring tab on the temperature probe cable connector and withdraw it from the probe port.
Remove the flathead screw on the USB networking door.
Loosen the captive Phillips #2 screw securing the monitor to the stand.
Insert a coin into the slot and push to open.
Remove the battery cover.
Remove the four Phillips #2 screws (labeled 14 in the service manual) from the rear housing.
With the handle/alert bar facing you, begin to lift the rear housing from the left side, holding the right side securely.
Disconnect the fan cable (labeled connector A in the service manual) from its socket in the power supply.
Unplug the small USB connector from its socket (labeled J4 in the service manual).
Disconnect the communications power cable from its socket (labeled J50 in the service manual).
Unplug the large USB connector from its socket (labeled J8 in the service manual).
Press the tab on the ethernet cable and unplug it from its socket (labeled J9 in the service manual).
The power supply cable is secured by an interlocking connector that must be held open to unplug the connector.
Grasp the power supply cable firmly and lift both it and the spudger from the channel in the power supply housing to unplug the connector.
Unplug the AC power harness connectors from the IEC connector with a pair of pliers.
Use the flat end of a spudger to lift the power supply up off the posts in the rear housing.
Lift and remove the power supply from the rear housing.
다른 한 분이 해당 안내서를 완성하였습니다.
