소개
Desoldering technique with [gootwitck mesh], hot air station and yihua soldering iron. (hot air at 100 ° C helps to preheat the control logicboard.)
동영상 개요
  1. Remove the battery pack cover.
    • Remove the battery pack cover.
    • Remove batteries.
  2. We recommend using a nylon spudger for this step. A metal spudger is shown.
    • We recommend using a nylon spudger for this step. A metal spudger is shown.
    • Grip the controller firmly to remove the side handles, wedging a spudger into the seam between the front and handle plates.
    • Pry the side plate away from the front plate by moving the spudger back and forth. You will need to do this all the way around the side plate's seam.
    • There is a hidden screw located in the middle of the controller behind the label.
    • Use a screwdriver and punch a hole directly in the center of the label.
      • You may also lift the label if you do not want to puncture it.
    • Remove the five 10mm screws located on the back of the controller using the T8 Security Torx Screwdriver.
    • Remove the backplate.
    • Remove the faceplate.
    • You may let the rumble motors hang freely out of their sockets.
    • De-solder the soldered joints while holding the red and black wires down on the top motherboard.
    • De-solder the black and gray wires that are attached to the top motherboard.
    • Remove the rumble motors and set them aside.
    • Be careful while using the soldering iron not to damage other components or hurt yourself.
    • For information on how to solder, click here.
    • Unscrew the two 7mm T6 screws located near the rumble motor sockets.
    • Firmly grip sides of motherboard near the middle.
    • Lift upwards while slightly wiggling the motherboard forward and backward.
    • Lifting the motherboard will require some force.
    • Remove the yellow tape holding the wires in place on the front of the controller.
    • Unscrew the two 7mm T6 Hex screws located on underside the triggers.
    • Remove the trigger covers.
    • Desolder the wires from the motherboard.
    • Remove the rumble motors from its socket and pull the wire with it.
    • Remove the six T6 Torx screws located on the bottom motherboard.
    • Remove the bumpers by prying them off of the pegs that secure them, using a spudger. They are located on the front and back of the controller.
    • A standard nylon spudger is recommended for this step. Using a metal spudger near the motherboard as shown risks damaging your device.
    • Lift the piece surrounding the Home button off of its pegs.
    • Pry it off of the other side, using a spudger on the pins.
    • Removing this piece may require a lot of force.
    • Remove the bottom motherboard.
결론
다른 2명이 해당 안내서를 완성하였습니다.
@HectorNavarroMX
회원 가입일: 2018년 06월 25일
1,010 평판
안내서 14개 작성하였습니다
조회 통계:
지난 24시간: 1
지난 7일: 12
지난 30일: 74
전체 시간: 74
