소개
Desoldering technique with [gootwitck mesh], hot air station and yihua soldering iron. (hot air at 100 ° C helps to preheat the control logicboard.)
필요한 것
동영상 개요
Grip the controller firmly to remove the side handles, wedging a spudger into the seam between the front and handle plates.
Pry the side plate away from the front plate by moving the spudger back and forth. You will need to do this all the way around the side plate's seam.
Use a screwdriver and punch a hole directly in the center of the label.
Remove the five 10mm screws located on the back of the controller using the TR8 Security Torx Screwdriver.
De-solder the soldered joints while holding the red and black wires down on the top motherboard.
De-solder the black and gray wires that are attached to the top motherboard.
Remove the rumble motors and set them aside.
Remove the yellow tape holding the wires in place on the front of the controller.
다른 3명이 해당 안내서를 완성하였습니다.
댓글 4개
Do you know where we can get the original analogue module for the joystick?
it does not exists, so you should buy generic replacement spare part
I just created welding related blog and you will find here more: bestmigwelders.org
