주요 콘텐츠로 건너뛰기
Wen 2307 Motor Replacement
필요한 것
  1. Wen 2307 Motor Replacement, Front Panel: 1 단계, 이미지 1/1
    • Unscrew the locking sleeve.
  2. Wen 2307 Motor Replacement: 2 단계, 이미지 1/1
    • Remove the hanging clip.
  3. Wen 2307 Motor Replacement: 3 단계, 이미지 1/2 Wen 2307 Motor Replacement: 3 단계, 이미지 2/2
    • Unscrew the six 8mm PH2 screws.
  4. Wen 2307 Motor Replacement: 4 단계, 이미지 1/1
    • While pressing the spindle lock button, unscrew the collet nut and remove it along with the brass collet.
  5. Wen 2307 Motor Replacement: 5 단계, 이미지 1/1
    • To remove the front panel, pry the device apart while holding the device with the other hand.
    • The front panel should come out easily.
  6. Wen 2307 Motor Replacement, Speed Adjustment Assembly: 6 단계, 이미지 1/1
    • Remove the connected wiring from the circuit board.
  7. Wen 2307 Motor Replacement: 7 단계, 이미지 1/1
    • Remove the single 4mm screw retaining the circuit board.
  8. Wen 2307 Motor Replacement: 8 단계, 이미지 1/1
    • Gently pry the circuit board from the back piece.
  9. Wen 2307 Motor Replacement, Motor: 9 단계, 이미지 1/1
    • Gently pull motor assembly out of the panel.
  10. Wen 2307 Motor Replacement: 10 단계, 이미지 1/1
    • Motor separates into two pieces.
결론
Joshua Bowery
회원 가입일: 02/08/16
549 평판
안내서 3개 작성하였습니다
USF Tampa, Team 12-1, Eyestone Spring 2016 USF Tampa, Team 12-1, Eyestone Spring 2016 회원
USFT-EYESTONE-S16S12G1
4 회원들
안내서 6개 작성하였습니다
댓글 한 개
All very well and good, but it’s impossible to buy the motor parts to replace…
Closetslave 1 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 6
전체 시간: 555
