주요 콘텐츠로 건너뛰기
Wen 2307 Power Cable Replacement
필요한 것
  1. Wen 2307 Power Cable Replacement, Front Panel: 1 단계, 이미지 1/1
    • Unscrew the locking sleeve.
  2. Wen 2307 Power Cable Replacement: 2 단계, 이미지 1/1
    • Remove the hanging clip.
  3. Wen 2307 Power Cable Replacement: 3 단계, 이미지 1/2 Wen 2307 Power Cable Replacement: 3 단계, 이미지 2/2
    • Unscrew the six 8mm PH2 screws.
  4. Wen 2307 Power Cable Replacement: 4 단계, 이미지 1/1
    • While pressing the spindle lock button, unscrew the collet nut and remove it along with the brass collet.
  5. Wen 2307 Power Cable Replacement: 5 단계, 이미지 1/1
    • To remove the front panel, pry the device apart while holding the device with the other hand.
    • The front panel should come out easily.
  6. Wen 2307 Power Cable Replacement, Power Cable: 6 단계, 이미지 1/2 Wen 2307 Power Cable Replacement, Power Cable: 6 단계, 이미지 2/2
    • Identify the screws.
    • Unscrew the two 3mm phillips PH2.
    • Don't forget to put them appart from the ones unscrewed before.
    • Phillips PH2
    • Flathead 2.5mm
  7. Wen 2307 Power Cable Replacement: 7 단계, 이미지 1/1
    • Remove the place boar carefully.
  8. Wen 2307 Power Cable Replacement: 8 단계, 이미지 1/1
    • Pull out the power cable connectors.
  9. Wen 2307 Power Cable Replacement: 9 단계, 이미지 1/1
    • Pull out the cord sleve for the new cable replacement.
결론
Sergio Palacio
회원 가입일: 02/08/16
437 평판
안내서 2개 작성하였습니다
USF Tampa, Team 12-1, Eyestone Spring 2016 USF Tampa, Team 12-1, Eyestone Spring 2016 회원
USFT-EYESTONE-S16S12G1
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 3
전체 시간: 446
