주요 콘텐츠로 건너뛰기
Westcott iPoint Evolution Outer Casing Replacement
필요한 것
  1. Westcott iPoint Evolution Outer Casing Replacement, Outer Casing: 1 단계, 이미지 1/1
    • Step 1: Start with the back of the pencil sharpener facing you.
    • This allows you to locate the power source.
  2. Westcott iPoint Evolution Outer Casing Replacement: 2 단계, 이미지 1/1
    • Step 2: Grab the end of the plug located at the bottom of the sharpener and pull it out gently.
  3. Westcott iPoint Evolution Outer Casing Replacement: 3 단계, 이미지 1/2 Westcott iPoint Evolution Outer Casing Replacement: 3 단계, 이미지 2/2
    • There are three parts of the sharpener.
    • Step 3: Grab the very top of the sharpener, twist it to the right and lift it up to remove it.
  4. Westcott iPoint Evolution Outer Casing Replacement: 4 단계, 이미지 1/3 Westcott iPoint Evolution Outer Casing Replacement: 4 단계, 이미지 2/3 Westcott iPoint Evolution Outer Casing Replacement: 4 단계, 이미지 3/3
    • Step 4: Grab the center of the sharpener and lift it up to remove the piece.
  5. Westcott iPoint Evolution Outer Casing Replacement: 5 단계, 이미지 1/3 Westcott iPoint Evolution Outer Casing Replacement: 5 단계, 이미지 2/3 Westcott iPoint Evolution Outer Casing Replacement: 5 단계, 이미지 3/3
    • Step 5: Remove the small ring that is around the sharpener.
    • This piece is below the center of the sharpener that you just removed.
  6. Westcott iPoint Evolution Outer Casing Replacement: 6 단계, 이미지 1/1
    • Step 6: Flip the pencil sharpener upside down.
    • Locate the four screws on the bottom of the sharpener.
  7. Westcott iPoint Evolution Outer Casing Replacement: 7 단계, 이미지 1/1
    • Step 7: Take a screwdriver and unscrew all of the screws on the bottom.
  8. Westcott iPoint Evolution Outer Casing Replacement: 8 단계, 이미지 1/1
    • Step 8: After all the screws are removed gently take off the bottom of the sharpener.
  9. Westcott iPoint Evolution Outer Casing Replacement: 9 단계, 이미지 1/1
    • Step 9: Carefully lift the lid off of the sharpener.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Lilly
회원 가입일: 06/02/16
167 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 17
30일 전: 42
전체 시간: 11,706
