주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Western Digital My Book Mini USB Port Replacement
필요한 것
  1. Western Digital My Book Mini USB Port Replacement, Mini USB Port: 1 단계, 이미지 3개 중 1개 Western Digital My Book Mini USB Port Replacement, Mini USB Port: 1 단계, 이미지 3개 중 2개 Western Digital My Book Mini USB Port Replacement, Mini USB Port: 1 단계, 이미지 3개 중 3개
    • Start by turning the device port side up.
    • With the plastic opening tool, pry along the edges of the case.
    • When you hear the case snap-out of its fitted grooves, slowly slide the board assembly out of the case.
  2. Western Digital My Book Mini USB Port Replacement: 2 단계, 이미지 1개 중 1개
    • Gently pull the three pronged, clear plastic piece from the rubber holder.
  3. Western Digital My Book Mini USB Port Replacement: 3 단계, 이미지 1개 중 1개
    • Unscrew the two screws from the motherboard.
  4. Western Digital My Book Mini USB Port Replacement: 4 단계, 이미지 1개 중 1개
    • Remove all the rubber pieces from the four corners to unhinge the motherboard.
  5. Western Digital My Book Mini USB Port Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the motherboard.
    • Set aside in a safe anti-static location.
  6. Western Digital My Book Mini USB Port Replacement: 6 단계, 이미지 1개 중 1개
    • Grab the mini USB port and align it with the appropriate metal docks on the motherboard.
  7. Western Digital My Book Mini USB Port Replacement: 7 단계, 이미지 1개 중 1개
    • Soldering irons can get HOT! Do not touch the iron tip, make sure it cools down for a good 30 minutes before touching the tip.
    • Start heating up the Soldering Iron, may take about 10–15 mins.
  8. Western Digital My Book Mini USB Port Replacement: 8 단계, 이미지 1개 중 1개
    • Solder together the four corners of the mini USB to the appropriate metal pieces on the motherboard.
    • Make sure the USB is firmly attached to the motherboard.
결론
To reassemble your device, follow these instructions in reverse order from step 8.
다른 8명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Gabriel Rael
회원 가입일: 06/24/15
333 평판
안내서 1개를 작성함
Colorado Springs, Team 1-2, Mcmichael SU 2015 Colorado Springs, Team 1-2, Mcmichael SU 2015 회원
UCCS-MCMICHAEL-SU15S1G2
2 회원들
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 28
지난 30일: 95
전체 시간: 18,410
