주요 콘텐츠로 건너뛰기
Wexford CT-166TF Air Filter Casing Replacement
필요한 것
  1. Wexford CT-166TF Air Filter Casing Replacement, Air Filter Casing: 1 단계, 이미지 1/1
    • Using a plastic opening tool, remove the four small foam pieces on the bottom of the fan.
  2. Wexford CT-166TF Air Filter Casing Replacement: 2 단계, 이미지 1/3 Wexford CT-166TF Air Filter Casing Replacement: 2 단계, 이미지 2/3 Wexford CT-166TF Air Filter Casing Replacement: 2 단계, 이미지 3/3
    • Remove the four screws that were uncovered in the previous step.
    • Remove the bottom cover using a spudger if needed.
  3. Wexford CT-166TF Air Filter Casing Replacement: 3 단계, 이미지 1/1
    • Remove the five screws that can be seen by aligning the base and the fan.
  4. Wexford CT-166TF Air Filter Casing Replacement: 4 단계, 이미지 1/2 Wexford CT-166TF Air Filter Casing Replacement: 4 단계, 이미지 2/2
    • Stand the fan upright. Locate and remove the two screws near the top.
  5. Wexford CT-166TF Air Filter Casing Replacement: 5 단계, 이미지 1/2 Wexford CT-166TF Air Filter Casing Replacement: 5 단계, 이미지 2/2
    • Locate and remove the two bottom screws.
  6. Wexford CT-166TF Air Filter Casing Replacement: 6 단계, 이미지 1/1
    • Remove the back casing by pulling it away from the front casing.
  7. Wexford CT-166TF Air Filter Casing Replacement: 7 단계, 이미지 1/2 Wexford CT-166TF Air Filter Casing Replacement: 7 단계, 이미지 2/2
    • Remove the two screws attaching the motor to the front casing.
  8. Wexford CT-166TF Air Filter Casing Replacement: 8 단계, 이미지 1/2 Wexford CT-166TF Air Filter Casing Replacement: 8 단계, 이미지 2/2
    • Remove the two middle screws connecting the air filter casing to the front casing.
    • Remove the front casing.
  9. Wexford CT-166TF Air Filter Casing Replacement: 9 단계, 이미지 1/1
    • Remove the four remain screws holding the air filter casing together
  10. Wexford CT-166TF Air Filter Casing Replacement: 10 단계, 이미지 1/2 Wexford CT-166TF Air Filter Casing Replacement: 10 단계, 이미지 2/2
    • Put the new air filter casing in place after cleaning the filter.
    • Repeat steps 1-9 in reverse order to properly put back together the fan.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Dannis Thompson
회원 가입일: 04/10/17
261 평판
안내서 2개 작성하였습니다
UW Tacoma, Team S3-G4, Liner Spring 2017 UW Tacoma, Team S3-G4, Liner Spring 2017 회원
UWT-LINER-S17S3G4
4 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 595
