주요 콘텐츠로 건너뛰기
Wexford CT-166TF Plastic Casing Replacement
필요한 것
  1. Wexford CT-166TF Plastic Casing  Replacement, Settings Knob: 1 단계, 이미지 1개 중 1개
    • Locate the knob at the top of the fan.
  2. Wexford CT-166TF Plastic Casing  Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the knob by gripping it and pulling straight up. Use a spudger if it is difficult to grip.
    • When reassembling, be sure to align the bottom of the new knob and the turning mechanism in the fan before pushing down.
  3. Wexford CT-166TF Plastic Casing  Replacement, Plastic Casing: 3 단계, 이미지 1개 중 1개
    • Using the plastic opening tool, turn the device over and remove the black plastic covers over the four screw holes.
  4. Wexford CT-166TF Plastic Casing  Replacement: 4 단계, 이미지 2개 중 1개 Wexford CT-166TF Plastic Casing  Replacement: 4 단계, 이미지 2개 중 2개
    • Remove the four screws underneath the plastic covers.
  5. Wexford CT-166TF Plastic Casing  Replacement: 5 단계, 이미지 2개 중 1개 Wexford CT-166TF Plastic Casing  Replacement: 5 단계, 이미지 2개 중 2개
    • Remove 5 smaller screws visible through small holes between the base and the casing.
  6. Wexford CT-166TF Plastic Casing  Replacement: 6 단계, 이미지 2개 중 1개 Wexford CT-166TF Plastic Casing  Replacement: 6 단계, 이미지 2개 중 2개
    • Remove four screws on the back, two near the top and two near the bottom.
  7. Wexford CT-166TF Plastic Casing  Replacement: 7 단계, 이미지 1개 중 1개
    • Pull off the back casing.
  8. Wexford CT-166TF Plastic Casing  Replacement: 8 단계, 이미지 2개 중 1개 Wexford CT-166TF Plastic Casing  Replacement: 8 단계, 이미지 2개 중 2개
    • Remove the 2 screws that attach the front part of the casing to the motor.
  9. Wexford CT-166TF Plastic Casing  Replacement: 9 단계, 이미지 2개 중 1개 Wexford CT-166TF Plastic Casing  Replacement: 9 단계, 이미지 2개 중 2개
    • Remove the two middle screws attaching the black plastic cover to the front .
  10. Wexford CT-166TF Plastic Casing  Replacement: 10 단계, 이미지 1개 중 1개
    • Remove the two screws attached to the white bar near the red light on the top of the front casing.
  11. Wexford CT-166TF Plastic Casing  Replacement: 11 단계, 이미지 1개 중 1개
    • Remove the two screws keeping the button attached to the top of the casing.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Cameron Mattson
회원 가입일: 04/05/17
101 평판
안내서 1개를 작성함
UW Tacoma, Team S3-G4, Liner Spring 2017 UW Tacoma, Team S3-G4, Liner Spring 2017 회원
UWT-LINER-S17S3G4
4 회원들
안내서 3개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 2
전체 시간: 406
