소개
Thermal appeal with down fill has to be treated specially. The general rule is: was as little as possible and as often as necessary. Use liquid detergent for fine wash or for functional clothing. We recommend Nikwax Down Wash.
필요한 것
There are symbols for the recommended care products on the smaller label. We recommend Nikwax Down Wash for the washing cycle and TX Direct Spray from Nikwax for waterproofing if necessary.
Down jackets usually are washed at 30 °C with a gentle cycle. You'll find detailed information on the sewn in care label.
Set your washing machine to a gentle cycle with extra rinse and the recommended temperature. If you are using NIKWAX Down Wash, you can omit the extra rinse cycle. The extra rinse cycle is important for ensuring that no residues are left behind on the product.
After the wash cycle, put the down jacket into the dryer with 2 to 3 tennis balls. Dry for 40 – 60 minutes at a low temperature using the gentle cycle.
Hang the jacket up on a clothes hanger, close all zips and spray evenly with the waterproofing spray. This keeps the inside untreated so that moisture can be absorbed and transferred outward.
다음 번역가들에게 특별히 감사 드립니다:
100%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
