주요 콘텐츠로 건너뛰기
Whirlpool Dryer Main Board Replacement
필요한 것
  1. Whirlpool Dryer Main Board Replacement, Safety Precautions: 1 단계, 이미지 1개 중 1개
    • Before you begin your repair, unplug your dryer.
    • Your power cord may have four prongs rather than three. The additional prong is a ground connection.
  2. Whirlpool Dryer Main Board Replacement, Unfasten the top panel: 2 단계, 이미지 3개 중 1개 Whirlpool Dryer Main Board Replacement, Unfasten the top panel: 2 단계, 이미지 3개 중 2개 Whirlpool Dryer Main Board Replacement, Unfasten the top panel: 2 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    FixMat
    $31.41
    • Throughout this guide, keep track of each screw and reinstall it exactly where it came from.
    • Use a nut driver to remove the screws securing the top panel to the rear panel bracket.
  3. Whirlpool Dryer Main Board Replacement, Remove the top panel: 3 단계, 이미지 2개 중 1개 Whirlpool Dryer Main Board Replacement, Remove the top panel: 3 단계, 이미지 2개 중 2개
    • Grasp the top and slide it 1/2 to 1 inch toward the rear of the machine.
  4. Whirlpool Dryer Main Board Replacement: 4 단계, 이미지 2개 중 1개 Whirlpool Dryer Main Board Replacement: 4 단계, 이미지 2개 중 2개
    • Lift the top panel upward to separate it from the chassis.
    • Remove the top panel from the machine.
  5. Whirlpool Dryer Main Board Replacement, Disconnect the Main Board: 5 단계, 이미지 2개 중 1개 Whirlpool Dryer Main Board Replacement, Disconnect the Main Board: 5 단계, 이미지 2개 중 2개
    • Disconnect all the wires from the main board.
  6. Whirlpool Dryer Main Board Replacement: 6 단계, 이미지 3개 중 1개 Whirlpool Dryer Main Board Replacement: 6 단계, 이미지 3개 중 2개 Whirlpool Dryer Main Board Replacement: 6 단계, 이미지 3개 중 3개
    • Continue disconnecting the main board.
  7. Whirlpool Dryer Main Board Replacement: 7 단계, 이미지 3개 중 1개 Whirlpool Dryer Main Board Replacement: 7 단계, 이미지 3개 중 2개 Whirlpool Dryer Main Board Replacement: 7 단계, 이미지 3개 중 3개
    • Finish disconnecting the wires from the main board.
  8. Whirlpool Dryer Main Board Replacement, Unfasten the main board cover: 8 단계, 이미지 3개 중 1개 Whirlpool Dryer Main Board Replacement, Unfasten the main board cover: 8 단계, 이미지 3개 중 2개 Whirlpool Dryer Main Board Replacement, Unfasten the main board cover: 8 단계, 이미지 3개 중 3개
    • Using a flat head screwdriver or a spudger, release the cover clips.
  9. Whirlpool Dryer Main Board Replacement, Remove the main board cover: 9 단계, 이미지 3개 중 1개 Whirlpool Dryer Main Board Replacement, Remove the main board cover: 9 단계, 이미지 3개 중 2개 Whirlpool Dryer Main Board Replacement, Remove the main board cover: 9 단계, 이미지 3개 중 3개
    • Lift the cover to release the tabs on the opposite side of the main board housing.
    • Remove the cover.
  10. Whirlpool Dryer Main Board Replacement, Release the main board: 10 단계, 이미지 3개 중 1개 Whirlpool Dryer Main Board Replacement, Release the main board: 10 단계, 이미지 3개 중 2개 Whirlpool Dryer Main Board Replacement, Release the main board: 10 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    Anti-Static Wrist Strap
    $7.16
    • There are six retaining clips securing the main board. Start at one end and work towards the other.
    • When you're handling the main board, wear an anti-static strap if possible, or regularly touch the exposed metal parts of the dryer to prevent electrostatic damage to the board.
    • Lift the board with one hand and use the other to release each clip with a spudger.
    • As you go, keep a gentle upward pull on the board so that the released clips don't snap back into place as you work.
    • Alternate sides of the board when releasing the clips.
  11. Whirlpool Dryer Main Board Replacement: 11 단계, 이미지 2개 중 1개 Whirlpool Dryer Main Board Replacement: 11 단계, 이미지 2개 중 2개
    • Release the remaining clips until the board is completely separated from its housing.
  12. Whirlpool Dryer Main Board Replacement, Remove the main board: 12 단계, 이미지 1개 중 1개
    • Remove the main board from its housing.
결론
Repair didn’t go as planned? Ask our Answers community for help.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Bill Gilbert
회원 가입일: 06/30/22
38,497 평판
안내서 261개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,610개를 작성함
1가이드 댓글
Hola, podrías decirme en el relevador qué tiene dos entradas, conterminales macho y se le conectan los cables contermi ales hembra, en cual va el cable de color rojo y en cual el negro?
JuanRamon - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 7
지난 30일: 63
전체 시간: 735
