주요 콘텐츠로 건너뛰기
Whirlpool Duet Steam Washer Drain Pump Replacement
필요한 것
  1. Whirlpool Duet Steam Washer Drain Pump Replacement, Drain Pump: 1 단계, 이미지 1개 중 1개
    • For your own safety, be sure to unplug the washer before proceeding.
  2. Whirlpool Duet Steam Washer Drain Pump Replacement: 2 단계, 이미지 1개 중 1개
    • To ensure that no more water passes through the washer, shut off the water by turning both handles all the way to the left.
  3. Whirlpool Duet Steam Washer Drain Pump Replacement: 3 단계, 이미지 3개 중 1개 Whirlpool Duet Steam Washer Drain Pump Replacement: 3 단계, 이미지 3개 중 2개 Whirlpool Duet Steam Washer Drain Pump Replacement: 3 단계, 이미지 3개 중 3개
    • Use a 1/4" socket or screwdriver to remove the sixteen 15 mm screws securing the rear access panel.
    • Remember: turn left to loosen and turn right to tighten!
    • Remove the rear access panel.
  4. Whirlpool Duet Steam Washer Drain Pump Replacement: 4 단계, 이미지 1개 중 1개
    • Pull the drain pump wire connector straight out of its port.
  5. Whirlpool Duet Steam Washer Drain Pump Replacement: 5 단계, 이미지 2개 중 1개 Whirlpool Duet Steam Washer Drain Pump Replacement: 5 단계, 이미지 2개 중 2개
    • Place your bowl or container under the drain hose before removal to catch any excess water that may be in the hose.
    • Use pliers to release the clamps securing the drain hose to the drain pump.
    • Pull the drain pump out.
  6. Whirlpool Duet Steam Washer Drain Pump Replacement: 6 단계, 이미지 2개 중 1개 Whirlpool Duet Steam Washer Drain Pump Replacement: 6 단계, 이미지 2개 중 2개
    • Use a 5/16" socket to remove the two 50 mm drain pump mounting screws.
    • There is one screw on each side of the pump.
    • Pull the drain pump down to remove it.
    • If it is difficult to remove, you can wiggle the pump in a side-to-side motion until it releases.
결론
작성자
4다른 기여자 명과 함께
Edgar Ibarra
회원 가입일: 03/15/22
133 평판
안내서 1개를 작성함
UM-KIM-S22SMG3 UM-KIM-S22SMG3 회원
Local Repair Groups
4 회원들
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 25
지난 30일: 152
전체 시간: 8,365
