주요 콘텐츠로 건너뛰기
Whirlpool Electric Range Oven Light Replacement
필요한 것
  1. Whirlpool Electric Range Oven Light Replacement, Oven Light: 1 단계, 이미지 1/1
    • Disconnect the oven from the power source.
    • Not removing the plug from the power could cause injuries or be fatal.
  2. Whirlpool Electric Range Oven Light Replacement: 2 단계, 이미지 1/1
    • Remove the oven racks for better movement.
  3. Whirlpool Electric Range Oven Light Replacement: 3 단계, 이미지 1/1
    • Remove the glass bulb covering by rotating it counterclockwise.
    • The bulb coverings look like little jars. There may be multiple bulbs in the back or side of the oven.
  4. Whirlpool Electric Range Oven Light Replacement: 4 단계, 이미지 1/1
    • Unscrew the bulb in a counterclockwise manner.
  5. Whirlpool Electric Range Oven Light Replacement: 5 단계, 이미지 1/1
    • Insert the new bulb in by rotating it in a clockwise manner.
  6. Whirlpool Electric Range Oven Light Replacement: 6 단계, 이미지 1/1
    • Screw the glass bulb covering back on in a clockwise manner.
  7. Whirlpool Electric Range Oven Light Replacement: 7 단계, 이미지 1/1
    • Reinsert the oven racks.
  8. Whirlpool Electric Range Oven Light Replacement: 8 단계, 이미지 1/1
    • Plug the outlet back in to the power source.
결승점
Kevin Patel
회원 가입일: 03/23/21
157 평판
안내서 1개 작성함
UMass Dartmouth, Team S1-G15, Sinclaire Spring 2021 UMass Dartmouth, Team S1-G15, Sinclaire Spring 2021 회원
UMASSD-SINCLAIRE-S21S1G15
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 9
30일 전: 63
전체 시간: 3,366
