주요 콘텐츠로 건너뛰기
Whirlpool Refrigerator Defrost Heater Replacement
필요한 것
  1. Whirlpool Refrigerator Defrost Heater Replacement, Safety precautions: 1 단계, 이미지 1개 중 1개
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. Whirlpool Refrigerator Defrost Heater Replacement, Open the doors: 2 단계, 이미지 3개 중 1개 Whirlpool Refrigerator Defrost Heater Replacement, Open the doors: 2 단계, 이미지 3개 중 2개 Whirlpool Refrigerator Defrost Heater Replacement, Open the doors: 2 단계, 이미지 3개 중 3개
    • Depending on your repair, open one or both doors.
  3. Whirlpool Refrigerator Defrost Heater Replacement, Remove the drawers: 3 단계, 이미지 2개 중 1개 Whirlpool Refrigerator Defrost Heater Replacement, Remove the drawers: 3 단계, 이미지 2개 중 2개
    • Remove the drawers and shelves from the freezer section.
  4. Whirlpool Refrigerator Defrost Heater Replacement: 4 단계, 이미지 2개 중 1개 Whirlpool Refrigerator Defrost Heater Replacement: 4 단계, 이미지 2개 중 2개
    • Remove the screw(s) securing the evaporator cover.
  5. Whirlpool Refrigerator Defrost Heater Replacement, Unclip the evaporator cover: 5 단계, 이미지 3개 중 1개 Whirlpool Refrigerator Defrost Heater Replacement, Unclip the evaporator cover: 5 단계, 이미지 3개 중 2개 Whirlpool Refrigerator Defrost Heater Replacement, Unclip the evaporator cover: 5 단계, 이미지 3개 중 3개
    • Lift the bottom of the evaporator cover up and over its lip in the chassis.
    • Pull the cover toward yourself to release its top clips.
  6. Whirlpool Refrigerator Defrost Heater Replacement, Remove the evaporator cover: 6 단계, 이미지 3개 중 1개 Whirlpool Refrigerator Defrost Heater Replacement, Remove the evaporator cover: 6 단계, 이미지 3개 중 2개 Whirlpool Refrigerator Defrost Heater Replacement, Remove the evaporator cover: 6 단계, 이미지 3개 중 3개
    • Continue pulling the evaporator cover towards yourself to unclip its metal prongs from the chassis.
    • Remove the evaporator cover.
  7. Whirlpool Refrigerator Defrost Heater Replacement, Disconnect the defrost heater: 7 단계, 이미지 3개 중 1개 Whirlpool Refrigerator Defrost Heater Replacement, Disconnect the defrost heater: 7 단계, 이미지 3개 중 2개 Whirlpool Refrigerator Defrost Heater Replacement, Disconnect the defrost heater: 7 단계, 이미지 3개 중 3개
    • Disconnect the connector(s) attached to the defrost heater.
  8. Whirlpool Refrigerator Defrost Heater Replacement, Reposition the cable: 8 단계, 이미지 3개 중 1개 Whirlpool Refrigerator Defrost Heater Replacement, Reposition the cable: 8 단계, 이미지 3개 중 2개 Whirlpool Refrigerator Defrost Heater Replacement, Reposition the cable: 8 단계, 이미지 3개 중 3개
    • Pull the defrost heater cable out from behind the evaporator.
  9. Whirlpool Refrigerator Defrost Heater Replacement, Unfasten the defrost heater bracket: 9 단계, 이미지 1개 중 1개
    • Remove the screw(s) securing the defrost heater bracket.
  10. Whirlpool Refrigerator Defrost Heater Replacement, Release the defrost heater bracket: 10 단계, 이미지 2개 중 1개 Whirlpool Refrigerator Defrost Heater Replacement, Release the defrost heater bracket: 10 단계, 이미지 2개 중 2개
    • Pull the defrost heater bracket up to release it from its slot in the chassis.
  11. Whirlpool Refrigerator Defrost Heater Replacement, Remove the defrost heater: 11 단계, 이미지 3개 중 1개 Whirlpool Refrigerator Defrost Heater Replacement, Remove the defrost heater: 11 단계, 이미지 3개 중 2개 Whirlpool Refrigerator Defrost Heater Replacement, Remove the defrost heater: 11 단계, 이미지 3개 중 3개
    • Slide the defrost heater from under the evaporator.
    • You may need to pull one end at a time until it's completely removed.
  12. Whirlpool Refrigerator Defrost Heater Replacement, Only the defrost heater remains: 12 단계, 이미지 1개 중 1개
    • You're now left with the defrost heater.
결론
Repair didn’t go as planned? Ask our Answers community for help.
다른 5명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
nicO
회원 가입일: 04/14/15
15,945 평판
안내서 89개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 10
지난 7일: 25
지난 30일: 130
전체 시간: 5,650
