주요 콘텐츠로 건너뛰기
Whirlpool Refrigerator Dispenser Solenoid Replacement
필요한 것
  1. Whirlpool Refrigerator Dispenser Solenoid Replacement, Safety precautions: 1 단계, 이미지 1개 중 1개
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. Whirlpool Refrigerator Dispenser Solenoid Replacement, Open the doors: 2 단계, 이미지 3개 중 1개 Whirlpool Refrigerator Dispenser Solenoid Replacement, Open the doors: 2 단계, 이미지 3개 중 2개 Whirlpool Refrigerator Dispenser Solenoid Replacement, Open the doors: 2 단계, 이미지 3개 중 3개
    • Depending on your repair, open one or both doors.
  3. Whirlpool Refrigerator Dispenser Solenoid Replacement, Remove the icemaker tray: 3 단계, 이미지 2개 중 1개 Whirlpool Refrigerator Dispenser Solenoid Replacement, Remove the icemaker tray: 3 단계, 이미지 2개 중 2개
    • Pull the icemaker tray completely out of its slot in the chassis.
  4. Whirlpool Refrigerator Dispenser Solenoid Replacement, Unfasten the icemaker assembly: 4 단계, 이미지 2개 중 1개 Whirlpool Refrigerator Dispenser Solenoid Replacement, Unfasten the icemaker assembly: 4 단계, 이미지 2개 중 2개
    • Remove the screw(s) securing the icemaker assembly.
    • The second photo shows the potential screw locations in a removed icemaker assembly.
  5. Whirlpool Refrigerator Dispenser Solenoid Replacement, Reposition the icemaker assembly: 5 단계, 이미지 3개 중 1개 Whirlpool Refrigerator Dispenser Solenoid Replacement, Reposition the icemaker assembly: 5 단계, 이미지 3개 중 2개 Whirlpool Refrigerator Dispenser Solenoid Replacement, Reposition the icemaker assembly: 5 단계, 이미지 3개 중 3개
    • Pull the icemaker assembly off its slot in the chassis.
    • Let the assembly hang to access its connectors.
  6. Whirlpool Refrigerator Dispenser Solenoid Replacement, Disconnect the icemaker assembly: 6 단계, 이미지 3개 중 1개 Whirlpool Refrigerator Dispenser Solenoid Replacement, Disconnect the icemaker assembly: 6 단계, 이미지 3개 중 2개 Whirlpool Refrigerator Dispenser Solenoid Replacement, Disconnect the icemaker assembly: 6 단계, 이미지 3개 중 3개
    • Disconnect any connectors attached to the icemaker assembly.
  7. Whirlpool Refrigerator Dispenser Solenoid Replacement, Remove the icemaker assembly: 7 단계, 이미지 1개 중 1개
    • Remove the icemaker assembly.
  8. Whirlpool Refrigerator Dispenser Solenoid Replacement, Unfasten the icemaker auger assembly: 8 단계, 이미지 1개 중 1개
    • Remove the screw(s) securing the icemaker auger assembly.
  9. Whirlpool Refrigerator Dispenser Solenoid Replacement, Reposition the icemaker auger assembly: 9 단계, 이미지 3개 중 1개 Whirlpool Refrigerator Dispenser Solenoid Replacement, Reposition the icemaker auger assembly: 9 단계, 이미지 3개 중 2개 Whirlpool Refrigerator Dispenser Solenoid Replacement, Reposition the icemaker auger assembly: 9 단계, 이미지 3개 중 3개
    • Pull the icemaker auger assembly off of its slot in the chassis.
  10. Whirlpool Refrigerator Dispenser Solenoid Replacement, Disconnect the icemaker auger assembly: 10 단계, 이미지 3개 중 1개 Whirlpool Refrigerator Dispenser Solenoid Replacement, Disconnect the icemaker auger assembly: 10 단계, 이미지 3개 중 2개 Whirlpool Refrigerator Dispenser Solenoid Replacement, Disconnect the icemaker auger assembly: 10 단계, 이미지 3개 중 3개
    • Disconnect any connectors attached to the icemaker auger assembly.
  11. Whirlpool Refrigerator Dispenser Solenoid Replacement, Remove the icemaker auger assembly: 11 단계, 이미지 1개 중 1개
    • Remove the icemaker auger assembly.
  12. Whirlpool Refrigerator Dispenser Solenoid Replacement, Remove the dispenser: 12 단계, 이미지 3개 중 1개 Whirlpool Refrigerator Dispenser Solenoid Replacement, Remove the dispenser: 12 단계, 이미지 3개 중 2개 Whirlpool Refrigerator Dispenser Solenoid Replacement, Remove the dispenser: 12 단계, 이미지 3개 중 3개
    • Slide the dispenser head out of its slot in the icemaker auger assembly.
  13. Whirlpool Refrigerator Dispenser Solenoid Replacement: 13 단계, 이미지 2개 중 1개 Whirlpool Refrigerator Dispenser Solenoid Replacement: 13 단계, 이미지 2개 중 2개
    • Remove the dispenser head out of its metal solenoid cube.
  14. Whirlpool Refrigerator Dispenser Solenoid Replacement, Remove the tape: 14 단계, 이미지 3개 중 1개 Whirlpool Refrigerator Dispenser Solenoid Replacement, Remove the tape: 14 단계, 이미지 3개 중 2개 Whirlpool Refrigerator Dispenser Solenoid Replacement, Remove the tape: 14 단계, 이미지 3개 중 3개
    • Peel the tape off the solenoid connector.
    • Set the tape aside. You'll reuse it during reassembly.
  15. Whirlpool Refrigerator Dispenser Solenoid Replacement, Disconnect the solenoid: 15 단계, 이미지 3개 중 1개 Whirlpool Refrigerator Dispenser Solenoid Replacement, Disconnect the solenoid: 15 단계, 이미지 3개 중 2개 Whirlpool Refrigerator Dispenser Solenoid Replacement, Disconnect the solenoid: 15 단계, 이미지 3개 중 3개
    • Disconnect the connector attached to the solenoid.
  16. Whirlpool Refrigerator Dispenser Solenoid Replacement, Meter the solenoid: 16 단계, 이미지 1개 중 1개
    • If you own a multimeter, you can test your solenoid's resistance.
    • A range between 10-500Ω is acceptable. Check your fridge solenoid specs sheet for more details. The pictured solenoid measured at 33.9Ω.
결론
Repair didn’t go as planned? Ask our Answers community for help.
작성자
2다른 기여자 명과 함께
nicO
회원 가입일: 04/14/15
15,945 평판
안내서 89개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 24
전체 시간: 1,191
