주요 콘텐츠로 건너뛰기
Whirlpool Refrigerator Door Light Replacement
필요한 것
  1. Whirlpool Refrigerator Door Light Replacement, Open the doors: 1 단계, 이미지 3개 중 1개 Whirlpool Refrigerator Door Light Replacement, Open the doors: 1 단계, 이미지 3개 중 2개 Whirlpool Refrigerator Door Light Replacement, Open the doors: 1 단계, 이미지 3개 중 3개
    • Depending on your repair, open one or both doors.
  2. Whirlpool Refrigerator Door Light Replacement, Unclip the door light: 2 단계, 이미지 2개 중 1개 Whirlpool Refrigerator Door Light Replacement, Unclip the door light: 2 단계, 이미지 2개 중 2개
    • Be careful during this step, as it's easy to scratch the interior of the fridge or crack cold and brittle plastic.
    • Carefully insert a flathead screwdriver, or a similar tool, between the door light and the chassis.
    • Pry up to separate the door light enough so you can grip it with your fingers.
  3. Whirlpool Refrigerator Door Light Replacement: 3 단계, 이미지 3개 중 1개 Whirlpool Refrigerator Door Light Replacement: 3 단계, 이미지 3개 중 2개 Whirlpool Refrigerator Door Light Replacement: 3 단계, 이미지 3개 중 3개
    • Tilt the door light downward to completely release its plastic clips.
    • Pull the light down to expose its connectors.
  4. Whirlpool Refrigerator Door Light Replacement: 4 단계, 이미지 3개 중 1개 Whirlpool Refrigerator Door Light Replacement: 4 단계, 이미지 3개 중 2개 Whirlpool Refrigerator Door Light Replacement: 4 단계, 이미지 3개 중 3개
    • Disconnect any connectors attached to the door light.
    • Remove the door light.
결론
Repair didn’t go as planned? Ask our Answers community for help.
작성자
3다른 기여자 명과 함께
nicO
회원 가입일: 04/14/15
15,945 평판
안내서 89개를 작성함
2가이드 댓글
Hello Gents,
I have a Kitchen aid fridge Model # KRFF300ESS01 and one of the top Led light is flickering they come as a set module # W10897058, and connected by interconnecting wiring, (concealed in the panel) can any one please help me as to how I can change them out.....the other light is good and there is a screw which holds up the plastic panel housing the lights, can I get them out by removing the panel or do I get them out by taking them out one at a time and how do I get the wiring in like that .....cant post any pictures but will appreciate any feed back,
ashley demonte - 답글
I have LED lights on sides and top. All three top lights are out, but side lights are still on. What can cause this?
Moose - 답글
댓글 쓰기
조회 통계:
지난 24시간: 7
지난 7일: 22
지난 30일: 171
전체 시간: 15,633
